Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 05-15-2019, 07:24 PM   #1
Marty68
S10 rear end id.
Can any of you gurus tell me what this is? Guy says s10 4x4. No truck avail to se spid. Counted rotations. 3.4. So probably 3.42. Is it an 8.5? Is there an external way to see if Gov lock? Prefer not. Intending rear differentisl and trans swap in 51 gmc with 283
Marty68 is offline   Reply With Quote
Old 05-15-2019, 09:51 PM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: S10 rear end id.
Not 8.5, its a 7.5. Measure it, I believe 60" wheel mounting surface to wheel mounting for surface on 4x4
on passenger axle tube stamp with axle codes
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 05-16-2019, 09:44 AM   #3
Marty68
will axle codes identify g80? and ratio? I don't care if 7.5 0r not. just not interested in g80 prefer 3.42 gears
Old 05-16-2019, 11:40 AM   #4
Warrens69GMC
It will indicate gear ratio and if it was a LSD, whether gov-lock or torsen is depending on year.
You can also take the cover off to verify all components are good before you go installing it in your project.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 05-16-2019, 12:45 PM   #5
Marty68
will it have the GU6 and G80 or some other code? asking dumb questions because I don't know... only want to buy one
Old 05-16-2019, 12:56 PM   #6
Warrens69GMC
pics
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 05-17-2019, 06:27 AM   #7
95 S_Trucker
95 S_Trucker's Avatar
Those codes are only listed on the spid, not on the axle/housing.
Pull the cover. That way you can inspect it, see what you have, and you’ll want to change the fluid anyways.
The 8.5 was used on 4.3 5 speed trucks/blazers, and all zr2 trucks(4” wider than reg 4wd, 8” wider than 2wd). The axle tubes are bigger at the center section and they neck down before the spring perches.
95 S_Trucker is offline   Reply With Quote
Old 05-17-2019, 03:19 PM   #8
Marty68
thank you
