Old 05-18-2019, 05:14 PM   #1
crossfire84
crossfire84's Avatar
Help with inside roof bow install
I need to see how the in side roof bows attach. i know the rear bow has screws to attach but the center bow has me scratching my head, any help or a photo would be awesome, thanks for all your help.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 05-18-2019, 08:19 PM   #2
joedoh
joedoh's Avatar
Re: Help with inside roof bow install
late 49 and up is a floating bow. meaning you install the front headliner section, then the bow slides on the front section straight, then you slide the rear section in and mount the rear bow with screws.
thats teh way it SHOULD work, with a cardboard headliner though I have fit the center bow to the front section, pinched it a little to hold it, then installed the front section with the center bow intact, then drilled two holes in the center bow, one on each side by the windlace, and screwed it too the cab with a pan head screw. then I was able to install the rear section. your results may vary, it might go right in the first way. I havent been that lucky.
