Old 05-19-2019, 12:12 PM   #1
04ls1gto
ls swap problems
swapped a 6.0/6l90 into my 71 suburban and it was trouble free for a few months of driving last year. I installed a AAW chassis wiring kit and now the gas pedal keeps dying. Thought the first pedal was just bad so I got one from PSI conversions who made the swap harness. Same thing, made it half a mile and it died. Any input on what to check?
04ls1gto is offline   Reply With Quote
Old 05-19-2019, 04:04 PM   #2
04ls1gto
Re: ls swap problems
a little more investigating and it seams ECU is tossing a PO606 code which is disabling pedal, clear the code and pedal works fine. Ill be calling tuner tomorrow to see if he can take a look
Old 05-19-2019, 10:15 PM   #3
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Check wire between pedal before you go to the tuner. Ohm it end to end and check for shorts
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 05-20-2019, 10:49 AM   #4
77c10bowtie
77c10bowtie's Avatar
double check all of your grounds also, you said everything was working find until you swapped the body harness, id start there. loose grounds are notorious for being a big issue on GM trucks and cars
77 SWB 2wd. gutted, caged, slicks, not weighed yet
02 Duramax CCSB 4x4 12.7@104 6750lbs
77c10bowtie is offline   Reply With Quote
Old 05-25-2019, 08:38 PM   #5
04ls1gto
Back in business, after some trouble shooting we loaded Corvette maps in and it runs great. No idea how it ran for the past few months without issue but I'll take it
