05-02-2019, 03:38 PM | #501 |
Re: Columbus..the 1957 IH 4x4..
thanks John!
05-12-2019, 09:51 AM | #502 |
Just went through this thread and wow, very nice. Looking forward to pictures of your parents when they get to drive it.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
05-12-2019, 03:41 PM | #503 |
Thanks 8man!!
05-13-2019, 02:26 PM | #504 |
Proprietor of Dale's Corner
I learned something about axle tubes. I never realized that they move with welding.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
05-13-2019, 11:05 PM | #505 |
Yeah Dale...heat distortion from welding will really make the metal change shapes...
05-18-2019, 04:39 PM | #506 |
I'm still making baby steps...work keeps getting in my way though...
Finally decided to quit trying to make some fancy looking coil mount brackets and just make something that would work....where they are and with everything assembled they'll be hard to see anyway...if they are a eyesore I'll make some covers for them... Heres the brackets I made...they bolt to the back of the heads And a pic of them mounted..
05-18-2019, 04:46 PM | #507 |
Side job on my hydroboost install was I needed a extra return port into the tank for it...I've seen where some just tee the lines together but have also heard some say it cavitates sometimes...
So I machined a nipple for the return... Cleaned up a spot on the tank and welded it on.. Then i stuck some magnets in the tank around where the hole would be and drilled on into the tank...I think it'll work
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 05-18-2019 at 10:29 PM. |
05-18-2019, 04:50 PM | #508 |
Also getting close to finalizing the brackets for the hydraulic clutch master...its still in r&d mode...turns out a 1:1 ratio was gonna work ok on the bellcrank..
I'll clean up and shape the brackets some..I had to order a banjo fitting to go on the reservoir end ..a 90deg -3an hose stuck up a little to high and was to close to the floorboard..
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 05-18-2019 at 04:57 PM. |
05-18-2019, 10:29 PM | #509 |
Making progress- keep it up
05-18-2019, 11:14 PM | #510 |
Nice work and progress
05-18-2019, 11:35 PM | #511 |
thanks tigger and Dale
05-20-2019, 11:22 PM | #512 |
Spent what little time I had today working on the plug wires...
I must say this just reaffirms the fact that I HATE wiring...It took most of the afternoon just to do one side. I'm using Taylors build your own wiring kit...the kit I have has the 10mm wires.. As I expected nothing goes as planned..their crimp tool sucks...it won't crimp the terminal properly...channel locks works better than the tool...the coil boots will test your patience...they dont slide easily on the wire jacket....even with the dielectric grease, wd40,hot water and youtube.....its a good thing I had extra boots..I had to cut 2 boots off the wire and redo just on the drivers side...they would stick to the wire just like they were glued on..and always in the wrong spot...but I got this side done.. I started on the pass side but needed to dimple the header tube on the front 2 cyl..the plug boots were just to close for comfort....and of course half way thru that I ran out of O2 for the torch... Oh well..I needed to cool down after doing the drivers side anyway... Drivers side done ...and the sucky little crimper...
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 05-20-2019 at 11:29 PM. |
05-21-2019, 12:18 AM | #513 |
May have been a pain but they is purdy....
05-21-2019, 12:44 AM | #514 |
Thanks Dale!....
05-21-2019, 08:21 AM | #515 |
That does look nice.
05-21-2019, 08:54 AM | #516 |
Hey Greg, did you try any Windex to move those boots around?
Brett 67 Camaro SS: 67 Camaro Build 72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build 72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD YouTube: https://www.youtube.com/@6dee7-7dee2 |
05-21-2019, 11:41 AM | #517 |
thanks 8man!!..
no 72...I didn't try windex...
05-21-2019, 03:58 PM | #518 |
Nice looking mounts and wire routing!
05-21-2019, 08:38 PM | #519 |
Thanks Doug!
05-21-2019, 10:56 PM | #520 |
Well I got the pass side done...for some reason it went a little easier than the 1st 4 did....
I'm gonna straighten the wiring up but 1st I've got to get some more wire separator clamps...thatll make it look some better...
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 05-21-2019 at 11:05 PM. |
05-21-2019, 11:02 PM | #521 |
I did some measuring and found what I think could have been some of the issues I was having...there is about .050 difference in the od of the wires...that makes it harder in the stripper/clamp and getting it in the plug boot...not to mention with a od range of .420-.470 and trying to get it in a .200 hole in the boot..
Like trying to cram 10lbs of crap in a 2lb sack... They sell the same boot for 10mm and 8mm wires...if I'd gone with 8mm it probably would have went much smoother...I did try the windex..it helped in the stripper part but not on the boot install...
05-22-2019, 11:12 AM | #522 |
All sounds too familiar. Great work!
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 |
05-23-2019, 05:10 PM | #523 |
Mike,i take it you had fun with this before?
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 05-25-2019 at 11:27 PM. |
05-26-2019, 10:10 AM | #524 |
Yep!
05-28-2019, 04:52 PM | #525 |
Got the clutch master mount and bell crank done...small progression but at least moving forward...
