Old 05-22-2019, 10:46 AM   #1
Dan-o
Turbo fuel injected 292 inline six.
I figured some of you may be interested in this. You may remember I put a TR6060 six speed manual behind this motor. here is the thread on that. https://67-72chevytrucks.com/vboard/...d.php?t=718750
current project is SPA t3 turbo manifold. Turbonetics turbo. cheap fleabay intercooler. FI-tech 600hp power adder fuel injection as a blow through setup. the plan is start at 5psi. probably no more than 6-7psi at the most. I'm not looking for huge power. just some fun.
motor has about 3000 miles on it N/A. mains and rods are all ARP studded. bored .040. head was redone. all new valves. 1.94 intakes. it has a small Howards cam .502 lift. about 212 duaration at .050"
Everything is mock up stages right now. I hope to fire it up in a few weeks.
Sorry I couldn't figure out how to get the pictures to show up. but the links should work.
https://lh3.googleusercontent.com/xn...=w1052-h789-no
https://lh3.googleusercontent.com/DY...=w1052-h789-no
https://lh3.googleusercontent.com/6z...=w1052-h789-no
https://lh3.googleusercontent.com/_u...=w1052-h789-no
Dan-o is offline   Reply With Quote
Old 05-22-2019, 11:07 AM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: Turbo fuel injected 292 inline six.
pics
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 05-22-2019, 11:11 AM   #3
Dan-o
thank you
Old 05-22-2019, 01:57 PM   #4
jcramsey
jcramsey's Avatar
Six speed, turbo, fuel injected 292? What's not to love about this?!
The Egg Hauler
The Government Mule
jcramsey is offline   Reply With Quote
Old 05-22-2019, 04:30 PM   #5
cj847
cj847's Avatar
Very interested in the fuel injection. I can't read the brand in the pic...what are you running? FAST, Holley, or other? And what manifold?
cj847 is offline   Reply With Quote
Old 05-22-2019, 04:34 PM   #6
Dan-o
FI-tech fuel injection. 600hp power adder version. manifold is an Offenhauser. Using a 2" 4 hole phenolic spacer to get it up high enough to run the hat over the valve cover.
Old 05-22-2019, 04:59 PM   #7
The Rocknrod
Moderator
The Rocknrod's Avatar
Yowza That is cool.
Old 05-22-2019, 08:29 PM   #8
hank scorpio
Oh man that's fantastic! Love this
64 C10
A bunch of Volvos
Luthier
Simpsons Nerd
hank scorpio is offline   Reply With Quote
Old 05-23-2019, 12:46 PM   #9
350TacoZilla
Cool project man! If you end up having issues with tuning try to switch that spacer for a open center style one. I personally have never ran anything like this but some guys have had problems with the TBI style fuel injection not liking the 4 hole style spacer, seems they like to spray into an open plenum type of deal to mix the air and fuel or you end up with some odd dips and spikes in AF ratio and power.
EDIT: you might be fine, just saying if it seems like your having fuel issues try the spacer before thinking its the whole EFI setup.
350TacoZilla is offline   Reply With Quote
Old 06-02-2019, 04:46 PM   #10
TJ's Chevy
TJ's Chevy's Avatar
Now a build like this is what I like!
Old 06-02-2019, 05:47 PM   #11
padresag
hope it works good for you
ron
padresag is offline   Reply With Quote
Old 06-03-2019, 03:18 PM   #12
Android04
Android04's Avatar
Can't wait to hear a video
Android04 is offline   Reply With Quote
Old 06-03-2019, 03:45 PM   #13
Killer Bee
Killer Bee's Avatar
definitely thinking outside the box.. looking forward to the test drive
Old 06-03-2019, 05:05 PM   #14
Robert Haas
Target on the Hp/Tq. numbers?
Robert Haas is offline   Reply With Quote
Old 06-04-2019, 04:11 PM   #15
Dan-o
https://photos.app.goo.gl/2F6WunoFVEp4VZsR7
here is a video, once again I don't know how to make it show up normal. the turbo sounds great here but its because it had a boost leak.
I ended up ripping the metal part of the driveshaft carrier bearing in half. and tore the driver side motor mount in half. new parts are on their way as well as the MSD pro billet distributor so I can use the FItech for timing control. boost is actually peaking at 11psi right now if i'm not careful. its a rocket ship for in inline six!
Old 06-04-2019, 04:13 PM   #16
Dan-o
no clue. 350hp minimum I'd say at the moment.
Old 06-04-2019, 11:25 PM   #17
Captainfab
60-66 Nut
It sounds like you have the light duty driveshaft and carrier bearing? If so you might want to consider upgrading to the HD carrier bearing and driveshaft.
Old 06-07-2019, 02:37 PM   #18
Android04
Android04's Avatar
I love that sound and miss it so much. Thanks for sharing
Old 06-09-2019, 12:17 PM   #19
hank scorpio
Friggin fantastic!!
64 C10
A bunch of Volvos
Luthier
Simpsons Nerd
Old 06-09-2019, 12:42 PM   #20
Ziegelsteinfaust
I would try a open spacer. It helps the carb or TBI in your case see the "pulses" if you will for a cleaner vacuum signal for better operation.
Also you can run safely up to 12 psi on a turbo because they work efficiently enough not to super heat the air up to around that point. Provided the turbo is not ridiculously small.
Lastly there are guys who supposedly take 2 sbc heads, and through the magic of heat + fire. Make a inline 6 head out of them.
Ziegelsteinfaust is offline   Reply With Quote
Old 06-09-2019, 01:09 PM   #21
rowdy11
That is clutch! Nice work!
1970 K10 Shortbed LS L96 6L90
Follow the entire mess below!
Lola: My Moon Shot
rowdy11 is offline   Reply With Quote
Old 06-11-2019, 10:54 AM   #22
straight6chevyguy
straight6chevyguy's Avatar
Sounds great!
1965 Chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 Chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 Chevy c20 350 4speed
1998 Chevy c1500 4.3L 5speed
1999 Chevy k1500 Suburban 5.7L auto 4x4
2002 Chevy s10 4.3L auto 4x4
1971 Mercury Monterey wagon 400 auto
Plus other misc. ... To many projects!
straight6chevyguy is offline   Reply With Quote
Old 06-14-2019, 05:16 PM   #23
Dan-o
Installed Locked out MSD Pro billet distributor so I can have fitech control the timing. New Prothane motor mounts installed do to tearing the old one in half.
Hope to get the timing set up tonight so I can take it to a show on sunday.
I also figured out how to do a picture correctly......
Old 06-26-2019, 04:07 PM   #24
drmatera
drmatera's Avatar
This is awesome. Great job
drmatera is offline   Reply With Quote
Old 10-01-2024, 12:54 PM   #25
Puddles
Hey there. I realize this is an old post but I was just curious what you did for fuel return with your turbo setup?
Did you run a full length return line from the fitech or did you use a a shorter return style setup like the corvette style fuel filter /regulator?.
Thanks for any info. I'm about to start running fuel lines to my turbo 292im using a sniper efi though.
Puddles is offline   Reply With Quote
