06-02-2004, 02:26 AM | #1 |
C10 now is a GMC
'67-72 exhaust kit
Hi Everyone,
I was wondering, is there a exhaust kit made for the '67-72 trucks? And can it be made to fit a '62 swb C10? I can't find one for the '60-62's or '64-66's, but could modify a '67-72 kit cause the frames should be the same (except with torsion setup). Since i have the torsion bar setup(front suspension), I have to use a "X" pipe in between the 2 adjustment bolts to run the duel exhaust under the frame. I even made a 1:24 scale model of the exhaust pipe on the model truck i'm building to use as an idea of what it should look like when it is finished. TIA, David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod *1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser *1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project |
06-02-2004, 05:08 AM | #2 |
graphic designer
i have seen a few kits from specialty manufactures like LMC and pickups northwest. might give them a try. i am smoewhat in the same predicament. i need a new system for my 72 and am looking into late model systems. the frames can't be THAT different, can they?
06-02-2004, 06:11 AM | #3 |
1 Wrench / 10 Knuckles
I have the LMC kit on my truck. It fit pretty well and with the turbo mufflers its not loud in the cab
1970 GMC Custom Vortec Heads, Edelbrock Performer Intake, Crane 272 Energizer, Hedman Full Length HTC Headers 2006 Dodge Charger SRT8. 1/4 mile 13.3 1973 Z1 900 Kawasaki ( all original) |
06-02-2004, 06:51 AM | #4 |
user # 2756
I installed the kit from JC whitney, it's a 2.25" dual kit. This is on my 71. Here:http://67-72chevytrucks.com/vboard/s...d.php3?t=97507
You'll have to scroll down there are a couple pics of the exhaust.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
06-02-2004, 02:31 PM | #5 |
C10 now is a GMC
That's exactly what i'm looking for.
'63-72 frames are the same (far as I know), but the '60-62's had a big "X" in the middle of the frame nick named the "wishbone" with torsion bar front suspension. With the "X" under there it's sure a PIA to work on the trans, or trying to slide the drive shaft into the back of the trans. Thank you guys so much for helping me. David
06-02-2004, 09:23 PM | #6 |
that truck has leaf springs,yours has trailing arms.the exaust would be different to fit around the trailing arms.
1964 c10 short step 1962 econoline van 1989 rs camaro 2006 yamaha vino 125 1975 goldwing |
06-02-2004, 10:30 PM | #7 |
Next project: 1970 K10
Here is an LMC kit in my 68 LWB (sorry for the sideways view). Fit nicely, and the turbo mufflers actually sound really good! I added the "H" pipe kit from Jegs.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
06-03-2004, 04:17 AM | #8 |
C10 now is a GMC
Glock35ipsc,
That exhaust looks pretty sweet. I'll have to check LMC. Many thanks, David
06-03-2004, 10:40 AM | #9 |
hey i thought the pipes were supposed to be routed over the traing arms,
is this correct? have you driven the truck with the exhaust on it yet? if thats the way it goes, i gotta take mine back apart. i haven t gotten mine on the road yet. thanks, tony
i survived cancer and kidney stones, but my kids are killing me. |
06-03-2004, 10:40 AM | #10 |
Have you tried the Hooker Headers cataloge. It's on the Holley carbs web site
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
06-03-2004, 11:24 AM | #11 | |
Since I am cutting the frame down to a short wheelbase, I will be cutting the system before and after the axle to make it fit the new frame length.
