Old 06-02-2019, 12:57 PM   #1
weedoublewide
LS bypass fuel pressure regulator question
Happy sunday!
Quick question,
I'm working on the fuel system on my swap need a little guidance.
Im working with the bypass fuel pressure regulator...Does it have to be plumbed to the top of the fuel tank or can it be tied back to the suction side of the fuel pump (external fuel pump).
I didn't know if it was purely vapors going back to the gas tank or liquids or a little bit of column a and a little bit of column b.
Thank you,
double.
weedoublewide is offline   Reply With Quote
Old 06-02-2019, 01:15 PM   #2
mongocanfly
mongocanfly's Avatar
Re: LS bypass fuel pressure regulator question
It needs to be a separate line back into the tank...not the suction side of the pump..
what filter/reg are you using?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-02-2019, 01:58 PM   #3
weedoublewide
I'm using this one.
https://www.jegs.com/i/JEGS/555/14410/10002/-1
I can make it happen to the tank, i just didn't know what was being returned to the tank. IE vapors left over from the rail, or liquid not being used from the rail...or a little bit of both.
Old 06-02-2019, 02:07 PM   #4
mongocanfly
it returns unused fuel back to the tank...that filter/reg is similar to the vett unit that ive used...be sure you plumb inlet and return correct..ive seen them hooked up backwards
I assume you have returnless fuel rails?
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-02-2019, 03:44 PM   #5
layinrocker65
layinrocker65's Avatar
It needs to be pumped back to the tank.
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 06-05-2019, 06:43 PM   #6
weedoublewide
That is a good question...i was looking the other day to where it pipes back into the tank...I'll double check that in the morning when I get back.
In the event it is an returnless fuel rail, whats a good fuel rail that has a return.
Old 06-05-2019, 07:48 PM   #7
mongocanfly
if your gonna use a return rail system you don't need a filter/reg....
the stock rails work just fine
returnless rail will need the filter/reg
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-08-2019, 09:17 AM   #8
weedoublewide
return-less rail will need the filter/reg
that was gonna be my next question, if it the original fuel system on the motor didn't have a return system on it before, why does it need one now? Better yet, why is it beneficial to have a return type fuel system
I have a pre and post filter on my fuel pump, so all i need is a regulator to set my psi going into the rail. Which means i can do away with the bypass regulator , since I'm going to go with the return-less rail system?
Best regards,
double
Old 06-08-2019, 09:48 AM   #9
mongocanfly
if you use a returnless rail you must have the regulator
if you use a return style rail you don't need a regulator
not sure what you mean by bypass regulator..unless your talking vett style filter/reg
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-08-2019, 09:58 AM   #10
mongocanfly
this is how mine is setup with the vet filter/reg with a returnless rail
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-08-2019, 10:01 AM   #11
mongocanfly
this is how a return rail system is setup
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-08-2019, 10:14 AM   #12
kipps
Originally Posted by weedoublewide View Post
Happy sunday!
Quick question...or can it be tied back to the suction side of the fuel pump (external fuel pump)
What you're suggesting would theoretically work, but is not recommended.
#1, as fuel bypasses the regulator, it heats up. You're looping this hot fuel through the pump again and again, instead of mixing it with cold fuel in the tank.
#2, it would be much more possible to airlock the fuel system when you run out.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 06-09-2019, 12:28 PM   #13
weedoublewide
Awesome, thank you man...yea im using the vette style reg too.
Did you use the stock fuel tank or get a new one with a return port in it already?
Old 06-09-2019, 12:30 PM   #14
weedoublewide
Okay that makes sense, hotter and hotter it would get and the psi would keep raising as well.
Thank you for you knowledge!
Old 06-09-2019, 01:25 PM   #15
mongocanfly
im using the stock tank...mine already had a return port on it
remember, the pressure side of the vet filter/reg is the outside port and the center port is the bypass back to the tank
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-10-2019, 07:55 PM   #16
weedoublewide
Otays then!
Nows I gotta find a way to fab up a return port for my stock tank then.
I appreciate the help mongo, I really do!!!
double
Old 06-11-2019, 07:42 AM   #17
nsb29
nsb29's Avatar
Not knowing what year truck you have this is what I did to my 65 I used a seconds sending unit and mounted an in tank fuel pump then I used the original fuel line as my return I used the Corvette filter/regulatorName:  357D2FEA-A536-434C-B714-6A0070DBA21F.jpg
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 06-12-2019, 05:48 PM   #18
weedoublewide
[QUOTE=nsb29;8540448]Not knowing what year truck you have this is what I did to my 65 I used a seconds sending unit and mounted an in tank fuel pump then I used the original fuel line as my return I used the Corvette filter/regulator
Wow, I was thinking today of how to use my existing sending unit and it didn't even cross my mind to use a second unit for the return....this is a URIKA moment lol.
I've never mounted an in tank fuel pump before, how difficult is that. I bought an external pump, but after some further research, I'm second guessing it and thinking about an intank pump.
and i have a regular old 1970 c10 long bed
Old 06-12-2019, 07:48 PM   #19
mongocanfly
I know several run incab/intank...nsb,dayj1,and others...mines external I've had no issues with it...your tank being in cab you may want to go internal...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-15-2019, 11:17 AM   #20
nsb29
nsb29's Avatar
It’s a pecs of cake but you have to make a ring to mount on the inside of the tank drill holes and tap threads you can see it cut in half on the bottom of the picture then spot weld it
Old 07-27-2019, 09:17 PM   #21
weedoublewide
Sorry for the no response, Hawaii trip changed my whole life lol.
Did you truncate the ends to both sending units or just the one for the fuel pump to mount?
Thanks,
double
Old 07-27-2019, 09:17 PM   #22
weedoublewide
I think that's what I'm gonna do....it sounds like the better way to do it.
Old 07-28-2019, 11:33 AM   #23
weedoublewide
What would be the harm of just using some quarter twenty stainless steel bolt with a washer, locknut and Loctite on it?
Old 07-28-2019, 03:39 PM   #24
ls1nova71
ls1nova71's Avatar
How would you hold them in there??
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 07-31-2019, 10:59 AM   #25
weedoublewide
you sir have a very good point, scratch my pervious question lol.
