Old 06-02-2019, 08:43 PM   #1
brian1115
LS Wire Harness Length?
Does anyone know if a stock ls harness from a truck will be able to mount the computer under the dash? Or do I have to extend it? If so by how much?
1986 Chevy Fleetside Wrangler (Canadian Only)
brian1115 is offline   Reply With Quote
Old 06-02-2019, 08:52 PM   #2
mongocanfly
mongocanfly's Avatar
Re: LS Wire Harness Length?
Should be plenty long..maybe to long unless you shorten it...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-04-2019, 03:29 PM   #3
layinrocker65
layinrocker65's Avatar
The factory harness runs off the top of the intake manifold to the drivers side fender well. I would be willing to but it won’t be long enough without a serious amount of modding to the harness.
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 06-04-2019, 08:50 PM   #4
kipps
Agree with this. The fuse box and ECM are mounted on the driver's side inner fender. There's no extra wire to go anywhere else. If you re-engineered the harness, you'd probably find that many of the wires will reach the cab because you're using a different route, but some of them will definitely be too short.
To answer your question about how much to lengthen the wires. If you leave the bulk of the harness as-is, and just turn the main pigtail of wires toward the firewall, I'd guess you need at least two more feet to get the ECM into an out of the way place in the dash. That would be minimum, but I haven't actually measured.
I'm simply putting my fusebox and ECM on the inner fender, where it's supposed to be.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
