Old 06-05-2019, 05:28 PM   #1
puttputt1977
Rear end question
I have a '64 GMC series 1000. My rear gear ate its self last week. My friend gave me a 5 lug rear end from '71-'72. What all needs to be done to get the newer rear end installed on my '64? I have a very limited budget. Thanks in advance for the help.
puttputt1977 is offline   Reply With Quote
Old 06-05-2019, 05:34 PM   #2
demian5
demian5's Avatar
Re: Rear end question
Are they both for a leaf or coil spring truck?
Should be a bolt in and go. You will have to get a pan hard bar that works. The 72 one may work, the 64 one is longer.
Post picture under the rear of your truck and of the replacement rear end. Instead of speculating on what you have, we can give definitive answers.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 06-05-2019, 05:56 PM   #3
puttputt1977
I dont know how to post pics but both rear ends are leaf spring. The newer rear end is 64" from outside of brake drum to outside of brake drum. My old rear end is 60.5" from outside of brake drum to outside of brake drum.
Old 06-05-2019, 06:22 PM   #4
puttputt1977
It looks like I have Dana 44 rear end under my truck now.
Old 06-05-2019, 06:29 PM   #5
Clyde65
Clyde65's Avatar
That’s what GMC’s has mostly.
The 71/72 will be 1.5” wider that your Dana I believe. If the leaf mounts line up, then go for it.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-05-2019, 07:35 PM   #6
puttputt1977
I measured from leaf spring bracket to leaf spring bracket and the difference is 3/4". Will I be able to use the new rear end?
Old 06-05-2019, 11:12 PM   #7
Captainfab
60-66 Nut
Sometimes there is enough movement in the spring eye bushings to be able to bolt up a differential with wider spring perch spacing. If not the spring perched will need to be cut off and welded back on at the correct spacing. Are the shock mounts the same between the two?
Old 06-05-2019, 11:18 PM   #8
puttputt1977
Captainfab, not sure. I didn't measure that one. I will do that tomo.
Old 06-06-2019, 11:42 AM   #9
PGSigns
PGSigns's Avatar
So where are you? I have some stuff that may help you out.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 06-06-2019, 01:05 PM   #10
puttputt1977
Jimmy
I'm in Salisbury NC.
Old 06-06-2019, 03:38 PM   #11
demian5
demian5's Avatar
So thats only 3/8" each side, bolt that thing up.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 06-07-2019, 06:43 AM   #12
PGSigns
PGSigns's Avatar
With Alberarle listed as your location thought you may be near the sound and bit more east. I have a 65 GMC frame with the Dana in it and if you want to make the trip you can have it. That will give you a bolt in fix and don't have to worry about shocks or pinion angle.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 06-07-2019, 02:05 PM   #13
puttputt1977
Jimmy
I appreciate the offer but you are 5 hours from me.
