Old 06-07-2019, 10:11 AM   #626
70STOVEBOLT
70STOVEBOLT's Avatar
Re: What did you do to your truck today.The 3rd chapter
Originally Posted by RodnRudy View Post
I did the 500 mile break in oil and filter change today. I'm using NAPA 10/30 with Lucas Oil additive that has the zinc in it. Also replaced the coil in the HEI, I've been having problems with the engine not wanting to start after driving a while and getting good and warm. I've replaced two modules and no luck so I'm trying a different coil.
If you have an Edelbrock carb without an insulator gasket, the fuel is probably boiling out of the bowl. I had this problem with the stock cast iron intake until I put an insulator gasket between the intake and the spacer plate.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 06-07-2019, 11:12 AM   #627
RodnRudy
RodnRudy's Avatar
I've got a phenolic 1/2" spacer under the carb so I don't have a fuel boiling problem. When this happened I checked for spark and had none, and then when the engine cooled down some I'd get the spark back and it'd run. I did a test run yesterday with the replacement coil and it started right up even though the engine was hot. What irks me is that this is a new GM distributor but of course it has a made in Mexico sticker on it.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 06-07-2019, 12:41 PM   #628
70STOVEBOLT
Sounds like you are on the right track then. Hope the new coil solves the issue.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 06-07-2019, 04:57 PM   #629
Steeveedee
Who Changed This?
Steeveedee's Avatar
Mexico doesn't have the same import requirements we do. A part can be imported from China to Mexico and then shipped to the US as "Made in Mexico".
~Steven
Simi Valley, CA
Old 06-09-2019, 10:31 AM   #630
Quikshft
Quikshft's Avatar
Yesterday I added back most of the trim/bumpers etc after completing the paint job. Still have a lot of molding to put on to complete the two tone look.
Quikshft is offline   Reply With Quote
Old 06-09-2019, 11:50 AM   #631
SoCoC10
SoCoC10's Avatar
I think I might be done with this one. Nice distraction while the K5 was back at the paint shop. Wanted to make a mini version of my 71 C10 Cheyenne SWB. There's more pictures and details in the "Our Stuff in scale" area.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 06-09-2019, 02:29 PM   #632
InNeedofaDelorean
Got dual exhaust put on, 2 inch pipe, 18 inch Cherry Bombs, and lucked into finding a set of slots from the cool dude I bought the truck from. Getting closer to that 70's look that I want.
1972 GMC 3/4 2wd "Phantom"
InNeedofaDelorean is offline   Reply With Quote
Old 06-09-2019, 09:17 PM   #633
NoStopN
NoStopN's Avatar
I took mine down the road for a photo op.
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline   Reply With Quote
Old 06-09-2019, 09:52 PM   #634
tdangle
tdangle's Avatar
Upped the initial timing from 8 to 14 degrees to make total amount 36 degrees. Much better throttle response. Need to get a tach that goes to at least 4K rpm to see when total advance is all in. I'm thinking that I need to recurve the HEI distributor
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 06-11-2019, 12:38 PM   #635
weq92f
weq92f's Avatar
Pulled out the old dizzy and prepped the new one for install...
MSD 8361:
Stock blue bushing will stay there for 21* of mech timing.
Placed one light blue and one light silver spring on the mech assembly, this should bring all 21* of mech timing in just under 2500.
Will stab it in soon...
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 06-11-2019, 05:16 PM   #636
72c20customcamper
72c20customcamper's Avatar
Since I can't paint my bed because my compressor went south. Can't complain its 27 years old . Motor is a GE 5 HP made in USA . Keeping that and the pump tank is shot. But I worked on the passenger door today. Inner door is all fixed and it fits very well little more body work and I'll paint it .
Picking up the new one tomorrow at Tractor supply. Getting the 80 gallon ingersal rand .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 06-11-2019, 06:40 PM   #637
WorkinLonghorn
WorkinLonghorn's Avatar
Changed the oil and filter replacing 10-30 with 10-40.
Replaced dimmer switch with ACDELCO D808 (Made in Taiwan-the first one i ordered didn't work).
Reconnected the wiper switch connector that has been off for 2 years now that the rain is done for the year and I won't need it.
This is fun, if it wasn't 96° out I'd do more. -BA
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 06-12-2019, 09:58 AM   #638
tdangle
tdangle's Avatar
It has been hot this week so far!!
Terry
Old 06-12-2019, 12:46 PM   #639
Steeveedee
Who Changed This?
Steeveedee's Avatar
Yup summer finally hit. It's been really nice up to now. The AC ran for the first time yesterday. I'm hoping that that means we're going to have a cooler summer again.
~Steven
Simi Valley, CA
Old 06-15-2019, 06:14 PM   #640
Astro-Balls
Astro-Balls's Avatar
Had the '68 Steam Cleaned today, took off about 100 lbs of dirt and grease..
Now i can see where all of the Zerk fittings are..
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 06-15-2019, 06:16 PM   #641
ohboy321
ohboy321's Avatar
Painted some of the parts needed to put the engine bay back together, but the best part was getting a 67 steering wheel in the mail. My 67 currently has a 70 style, and I can't wait to put the correct one in. It was a good deal on a "buy it now" on the auction site, and the bonus was the nice horn button with no broken tabs that came with it. Plus it has all the internals to make it go beep! Will eventually restore it in black, but will install as-is to enjoy for now. Benny likes it...
ohboy321 is offline   Reply With Quote
Old 06-16-2019, 01:07 AM   #642
Richard Jensen
Hello,
Replaced my after market, all aluminum radiator. Well out of warranty, but the rad shop owner checked for electrolysis but didn't see any and after discussing it with the maker, they decided to issue a new replacement!!! Also checked/cleaned the ground from the battery to rad support and installed new air cleaner element. Tommorrow's plans include servicing the rest of the truck (oil, grease, filters) and checking all of the rest of the grounding straps. If time allows, rotating the tires. Rad shop was Best Radiators in Hays ks.
Lead, follow, or get out of the way!
Richard Jensen is offline   Reply With Quote
Old 06-16-2019, 09:37 AM   #643
Chuck A
Chuck A's Avatar
Changed out my starter and starting circuit due to a no start condition. When I came across this splice in the ignition wire, I knew I was doing the right thing. Yes, that is a common household wire nut.
Chuck A is offline   Reply With Quote
Old 06-16-2019, 03:13 PM   #644
Redneck Rydes
Redneck Rydes's Avatar
Now that was a mess
Redneck Rydes is offline   Reply With Quote
Old 06-17-2019, 11:38 PM   #645
3757chevy
3757chevy's Avatar
I test fit fit my bed wood Today in between thunder storms. And I marked their position for later. Still a ways off from done.
'67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 06-18-2019, 07:33 PM   #646
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do to your truck today.The 3rd chapter
Got home Saturday from the 2019 Hot Rod Power Tour. Washing the truck Sunday and noticed brake fluid between the master cylinder and booster.
Called and ordered it got it Monday and painted it and installed it today. Bleed everything and now have brakes again.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 06-20-2019, 10:15 PM   #647
Astro-Balls
Started removing the two auxiliary tanks today to have them cleaned out if possible, I would like to save them.
Tanks have not been used in 20 years, we will see what they look like inside when they are removed...
Old 06-21-2019, 12:27 AM   #648
WorkinLonghorn
That is one of my next projects too. I just bought 10 feet of 3/8" fuel line to connect up the three tanks. I used to use all three but I can't remember why I disconnected the saddle tanks. I do remember that the passenger side one would clog the filter regularly so I used the driver side one. I'll be watching your progress, if you post here or start a thread.
Old 06-21-2019, 05:44 PM   #649
72c20customcamper
Prepped the bed for the 68 for paint. Just need to hit it with 400 and spray it tomorrow. Did the steelies for the 72 came out nice. PPG single stage urethane they were definatly powder coated MEK didn't touch it bought them last year from road ready wheels. First picture is sanded. Second after two coats third after three and pretty much cured.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-21-2019, 08:11 PM   #650
Astro-Balls
Got the Saddle tanks pulled today, Noticed a tear in each side of the bedside due to where they mounted the tank bracket to the lower wheel well.
