Old 06-07-2019, 12:01 PM   #1
elorenzof
Help Identifying misc parts
If i could get some help here... 1972 K10 - I have this box of misc parts that have been powder coated and i need help with identification?
elorenzof is offline   Reply With Quote
Old 06-07-2019, 12:14 PM   #2
Daaaanz67
Re: Help Identifying misc parts
What year did these parts come off of. #3 looks part of shift linkage that’s mounted on the frame right across from the trans. Shift rod from column goes down to another pivot assembly. That assembly pivots on the shaft of #3. Then another rod attaches to the trans.
Daaaanz67 is offline   Reply With Quote
Old 06-07-2019, 12:25 PM   #3
elorenzof
[QUOTE=Daaaanz67;8538385]What year did these parts come off of. #3 looks part of shift linkage that’s mounted on the frame right across from the trans. Shift rod from column goes down to another pivot assembly. That assembly pivots on the shaft of #3. Then another rod attaches to the trans.[/QUOTE
Oops sorry... it's a 1972 K10
Old 06-07-2019, 12:39 PM   #4
CharlieBrown
CharlieBrown's Avatar
#4 is transfer case mount to side of frame I believe
1972 Cheyenne Super..owned since 1978
1972 Surburban 4x4
1972 Cheyenne 4x4 3/4 ton.....sold
1972 Cheyenne 2wd...named Death Row
CharlieBrown is offline   Reply With Quote
Old 06-07-2019, 01:06 PM   #5
sick472
sick472's Avatar
#2 and 3 are part of the auto trans shift linkage. #3 bolts to the frame and #2 hangs off of it and then connects to the trans and column shift linkage.
I think #10 is from under the dash, but I just can't quite place it.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 06-07-2019, 01:17 PM   #6
notsolo
notsolo's Avatar
#5 is exhaust hanger above shifter linkage...# 9 is bracket that holds diaphram passenger kick panel.
notsolo is offline   Reply With Quote
Old 06-07-2019, 01:24 PM   #7
kwmech
#1 one of the parking brake anchors
#2 Auto trans pivot
#3 Auto trans frame pivot anchor
#4 Transfer case torque mount (bolts to t-case)
#5,8,9 need a close up pic
#6 Looks like a door striker plate back up
#7 Left front leaf spring stop plate (shackle end)
#10 Goes with #4 but bolts to frame
#11 ?? looks like the newer style magnet that sits inside a trans pan
Old 06-07-2019, 01:29 PM   #8
dfwright
dfwright's Avatar
#11 looks like a cab mount spacer
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 06-07-2019, 01:59 PM   #9
MJN
MJN's Avatar
#4 and #10 are for the transfer case torque mount bracket. This picture is from my '74 K20 but its assembled the same. #4 mounts to the transfer case and #10 is the bracket mounted to the inside of the frame rail.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 06-07-2019, 02:04 PM   #10
dflarsen77
Active Member
I think 2 and definitely 3 are part of a shift linkage. 6 is the backing plate to a door striker. 8 is the bracket that attaches to the back of one of the interior vent doors. 9 is the bracket for a vacuum solenoid that opens and closes the passenger side vent door. 11 looks like the cig lighter trim? Maybe take a shot from different angles to see the parts better.
David Larsen
1970 Chevrolet C-10
dflarsen77 is offline   Reply With Quote
Old 06-07-2019, 03:02 PM   #11
elorenzof
You guys are all awesome. thanks for the help. I received this truck and a box of parts. The parts in the pic I couldn't identify but thanks to you all I think the mystery has been solved!
Old 06-08-2019, 02:22 AM   #12
randy500
11 is a worn out portion of a front upper cab mount
randy500 is offline   Reply With Quote
Old 06-08-2019, 02:23 AM   #13
randy500
9 is the bracket for the ac vacuum pod inside the cab at the rh vent.
Old 06-08-2019, 02:24 AM   #14
randy500
8 is the bracket, rh vent that screws to the vent door, connects to vacuum pod link
