Old 06-10-2019, 08:28 AM   #1
8man
Altman latches and electric locks
I have the Altman latches installed on the 48, and I used the original door key lock on the rider's side. It will lock and unlock with the key, but then there is no way to lock the driver's side.
So I got electric locks (not installed yet) and when testing the rider's side realized the key door lock won't let the electric locking mechanism to move the Altman lock on the door.
If I disconnect the key door lock, then the electrics will work on both doors, but the only way to unlock/lock is with the electric and if the battery goes bad, what do you do?
So what have others done?
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 06-10-2019, 10:09 PM   #2
FiftyTwo
FiftyTwo's Avatar
Re: Altman latches and electric locks
On thing you could do is simply add another key lock to your driver's door handle. They sell two locks with matching keys pretty cheap.
FiftyTwo is offline   Reply With Quote
Old 06-11-2019, 09:46 AM   #3
dsraven
pics? fab up a bell crank with mechanical advantage to make the door key move the electric lock further so it works (if thats the issue)
Old 07-04-2019, 11:11 PM   #4
ozzie50
I added remote battery terminals. I have the same set up as you.
ozzie50 is offline   Reply With Quote
