Old 06-10-2019, 09:27 PM   #1
Cheyenne350
Alternator problems
Im confused here with the problem I just started having not too long ago. I have 69 Chevy c10 with a built 350 ZZ4 heads, 750 demon carb XE284H comp cam. Alternator will drain the battery while truck is running and will drain it completely dead. I’ve done the trick where you turn on the truck remove battery alternator will stay running but once put into gear engine dies.
I’m guessing it’s the alternator but asking around will say I have a short somewhere. Alternator is a 14 volts 100amps, asking summit racing tech support advice me to get a 12volts 100amps and that should solve my problem. Any help here would be appreciated thanks!
Cheyenne350 is offline   Reply With Quote
Old 06-10-2019, 09:47 PM   #2
firedemon
Re: Alternator problems
whats the idle speed when idol and when in gear ? assume its an internal regulator being 100 amps . 1 wire or 3 wire ?
firedemon is offline   Reply With Quote
Old 06-10-2019, 10:12 PM   #3
firedemon
only 12 volts on a street engine will cause you problems especially if you have an hei ignition once you start using other electric stuff like headlights and things it will be worse . lets figure out why the regular alt isn't working its more of what you need
Old 06-10-2019, 11:04 PM   #4
Cheyenne350
Firedemon- idle speed is at 500 and its 2 wire hook up. In a way your suggesting not a 12 volts to get but perhaps more amps with the 14 volts I have?
Old 06-11-2019, 07:10 AM   #5
Minkota
As for stalling when you put it in gear, thats a pretty big carb, so I am assuming you have a decent size Cam. Does it have a Stall?
Minkota is offline   Reply With Quote
Old 06-11-2019, 08:02 AM   #6
Mike C
Mike C's Avatar
Alternators designed/rated for a 12v system put out 14 volts. Usually 14.1 or 14.2 by design to charge the battery need higher voltage output than the battery. It sounds like the internal regulator is shorted in the alternator you have. Just replace it with an alternator of similar ouput.
You can also rebuild the regulator portion of the alternator and see if that doesn’t solve your problems.
I like 12si alternators from an mid 80’s Suburban. Should be 95 amps and can be picked up brand new on Rock Auto for less than $100. Fits in the same spot as the 10si just the fan looks different.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-11-2019, 08:13 AM   #7
rpmerf
rpmerf's Avatar
First thing I would do is to measure the voltage at the battery while running. If it isn't about 13.8-14.5 volts, the alternator is not charging. Take it to an auto parts store and have them test it.
If it isn't charging and it test good, look into the wiring, especially the exciter wire and the reference wire.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 06-11-2019, 11:20 AM   #8
brown7373
brown7373's Avatar
I see you run electric fans, which suck a lot of juice. I would think a 100 amp if working and regulated properly should handle it though. Any of my vehicles have 14+ volts at the battery when running.
brown7373 is offline   Reply With Quote
Old 06-11-2019, 09:43 PM   #9
firedemon
your idle should be 700 - 750 I believe in gear probably around 900 at idle. im thinking you probably have enough amps already unless your running electric fans and lots of other electric stuff . get the idle up and read the voltage at the battery should read 14- 14.5 if not check the thick wire post on the back of the alternator and see if its 14 or better again if not , check the brown wire for voltage on the 2 wire connector on the alternator it should be 12 or better . if the brown wire has power and crap for voltage on the rest the alt is bad if power is good on all you have something drawing it down witch is another fun problem . if no power on the brown you will have to trace it back and see where it is not feeding again fun
