Old 06-13-2019, 02:05 PM   #1
Kuzican
Kuzican's Avatar
1/2 ton caliper pin bolt
Need help, I stripped out a caliper pin bolt on 83 1/2 ton. I need the thread size Were I can tap it out or Heli - coil it. Don’t want to replace spindle it’s a 2.5 lowering one. Thanks !!
Kuzican is offline   Reply With Quote
Old 06-13-2019, 03:01 PM   #2
thirstybob
Re: 1/2 ton caliper pin bolt
I did the same thing on my C20. Napa had a "repair" pin that I used. Slightly oversized threads and a little harder steel to cut new threads. Worked good except they say it's a one time use only.
thirstybob is offline   Reply With Quote
Old 06-15-2019, 12:58 PM   #3
Kuzican
Kuzican's Avatar
Any one know? 7/16-20 ? 11-1.5 ?
Old 06-15-2019, 01:38 PM   #4
mongocanfly
mongocanfly's Avatar
I looked when you 1st posted but couldn't find a definite answer...sometime in the early 80s they went from standard to metric...take one of your bolts to your local parts store,,,or fastenal if you have one close by ...most have a thread pitch gauge and they can tell you if its standard or metric....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-15-2019, 01:50 PM   #5
kwmech
7/16.
Old 06-16-2019, 04:39 PM   #6
Axle
Axle's Avatar
Brazed up the sides of the hole in mine and re-tapped it for the stock pin, figured if that failed the oversize pin will be plan B.
Axle is offline   Reply With Quote
