Old 06-13-2019, 07:25 PM   #1
RogerKoop
RogerKoop's Avatar
Very nice restored pickup A/T Tilt Column
I just completed 2 more A/T tilt columns and are ready for shipping
I have for sale a very nice restored pickup A/T Tilt Column.
The rebuild includes a complete disassembly and inspection for worn or broken parts. This is followed by cleaning and bead blasting most parts. The Hub and Housing are powder coated. The rest of the column is then painted and rebuilt to factory specs. This includes packing and set torque to factory specs on upper bearing assembly. The lower bearing is cleaned and repacked. The dust or air seal is replaced with a new one. I have the lower bearing retainer and the screws that mount to neutral safety / backup light switch, as well as the horn button contact parts re-cadmium plated. The original turn signal harness is checked using one of my trucks. It will be reused if it passes the use test. It is then cleaned and re-greased. A new turn signal harness is available on request. The column is rebuilt using new, NOS and quality used parts. Column is ready to bolt in.
On automatic columns the neutral safety/backup light switch is installed and has been adjusted to match the shift indicator. No additional adjustment should be needed, just plug and play.
I also have a number of original shifter arms that have been re-chromed. All of them are high quality show chrome. I have both the standard pickup shifter as well as some out of vans which are about 4” shorter. Some owners opt for the shorter shifter based on a smaller steering wheel size. The price is $50.00 for either.
Price for column is $695.00 plus shipping to CONUS. I accept Checks and PayPal. Please include your shipping address. I will ship this via UPS.
I have several more columns to complete, so if you would like one let me know.
The following New or NOS parts were installed:
- Lower Inner Dust Seal
- Upper Rubber Gasket to Dash Bezel
- Lower Rubber Gasket to Firewall
- Shifter Arm
- Shifter Arm Knob
- Tilt Release Arm
- Turn Signal Arm
- Tilt Pointer
- Transmission Indicator Lens
- Neutral safety / backup light switch
Roger Koop
RogerKoop is offline   Reply With Quote
Old 06-13-2019, 07:26 PM   #2
RogerKoop
RogerKoop's Avatar
Re: Very nice restored pickup A/T Tilt Column
More Pics
Roger Koop
Old 06-14-2019, 07:28 AM   #3
randy.powell
Here's a Friday "bump" for you Roger.
It's beautiful!
randy.powell is offline   Reply With Quote
Old 07-31-2019, 07:48 PM   #4
RogerKoop
RogerKoop's Avatar
ttt
Roger Koop
Old 11-16-2019, 10:08 PM   #5
RogerKoop
RogerKoop's Avatar
ttt
Roger Koop
Old 07-30-2020, 07:23 PM   #6
RogerKoop
RogerKoop's Avatar
ttt
Roger Koop
Old 07-31-2020, 03:01 PM   #7
TrkEnvy
I’m interested in this item. Can you pm me how much to ship it to 89129??
1971 C10 - LWB shortened to SWB, welded in my C notch, reinforced trailing arms with 3/16 plate, new cpp 5" rear drop springs, 2" drop blocks, ece super panhard kit. Cpp drop spindles, 2 inch front springs, 5.3/4L80E
I call it Bruce Banner..
TrkEnvy is offline   Reply With Quote
Old 08-02-2020, 11:12 AM   #8
72 Jimmy Power
Hi, What is shipping to 94080?? Thanks.
72 Jimmy Power is offline   Reply With Quote
Old 08-02-2020, 12:01 PM   #9
RogerKoop
RogerKoop's Avatar
PM sent
Roger Koop
Old 09-16-2024, 11:54 AM   #10
RogerKoop
RogerKoop's Avatar
ttt
Roger Koop
Old 09-16-2024, 12:21 PM   #11
mike1971c10
mike1971c10's Avatar
Roger, What would the shipping cost be to 85043? I need to see if I have enough money hidden from the wife
mike
my build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522167 vietnam vet 67-68
mike1971c10 is offline   Reply With Quote
Old 09-16-2024, 06:08 PM   #12
mike1971c10
Roger, I'll take it. PM we your address so I can send you a check
mike
Old 09-16-2024, 08:27 PM   #13
RogerKoop
RogerKoop's Avatar
mike
Roger Koop
6975 Mize RD
Shawnee, KS 66226.
I'll box it up. Thanks
Roger Koop
Old 09-17-2024, 02:06 PM   #14
mike1971c10
Roger, checks in the mail
mike
