Old 06-16-2019, 11:37 AM   #1
cfan10
cfan10's Avatar
Cool Dropped tank for gas gauge
OK, so this morning I decided I will not tolerate the gas gauge that doesn't/hasn't ever worked properly since I bought the truck.
After dropping the passenger side tank I realized there is no broken off purple wire coming off of the sender, had the sender installed in '10 I believe it still works fine but has no connection for the purple wire that's grounded on the frame, that's I'm told is what sends the signal to my gas gauge. I just want my gas gauge to work, I've brought about six or seven junkyard clusters over the years I was young and got taken advantage of by not so good shops/mechanic's. Gas gauge always went to like 3 o clock, way past full.
As always thanks in advance!
'84 c10 350/350 dual tanks, only using the passenger tank and it's hooked up to an external electric fuel pump.
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me.
Don't mess with my truck, my momma or my money...not necessarily in that order. ©
Stand for something or fall for anything.
[LIST][*]'98 Bourbon St. Brawl ©2010
cfan10 is offline   Reply With Quote
Old 06-16-2019, 12:12 PM   #2
Dead Parrot
Re: Dropped tank for gas gauge
Normal colors are pink wire to gauge and black wire to frame/ground.
3 o'clock = open circuit somewhere.
Dual tank switch can also be a source of open circuit. If original, it is about 35 years old and probably been hit by more then one knee.
Dead Parrot is offline   Reply With Quote
Old 06-16-2019, 12:19 PM   #3
cfan10
cfan10's Avatar
Cool Re: Dropped tank for gas gauge
Purple wire grounded on top of frame...goes where?
Old 06-16-2019, 12:20 PM   #4
cfan10
cfan10's Avatar
More...
Old 06-16-2019, 12:51 PM   #5
Bandit130
Bandit130's Avatar
Mine was always pegged at 3'oclock. New tank, hoses and sending unit then worked correctly. The sending unit on mine was bad.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is online now   Reply With Quote
Old 06-16-2019, 03:28 PM   #6
kipps
First thing I would check while the fuel sending unit is out-- Connect an ohm meter between clean metal on top of the sender and the pink? wire from the sender. As you move the sender through its full sweep, you should see it smoothly go from nearly 0 ohms to approximately 90. If so, your sender is fine, and the problem is the wiring or the gauge.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 06-16-2019, 11:38 PM   #7
fordguy40
If I remember right, that wire should be attached to a tab on the sending unit near the retaining ring.
A few Fords and a couple of Chevys
fordguy40 is offline   Reply With Quote
Old 06-16-2019, 11:53 PM   #8
dieseldawg142
dieseldawg142's Avatar
this...
had the same prob.
trace the pink wire back to the cab looking for any points of contact in the wire.
wire clamp had chafed my pink and sent it to 3 o'clock
dieseldawg142 is offline   Reply With Quote
Old 06-17-2019, 12:21 AM   #9
hatzie
Moderator
hatzie's Avatar
Likely to the sender ring... There should be a 1/4" wide tang on the sender tank ring that the short ground wire plugs into.
Purple is not the original factory tank ground wire color but I bet that's what it is. OEM GM tank ground wire color is black.
That disconnected ground wire can and will cause the gauge to sit at 3:00.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
