Old 06-22-2019, 05:01 PM   #1
HeavyHauler
How to properly check fluid level for 400 turbo transmission
I have not owned a chevy in a long time. How do you properly check the fluid level for a 400 turbo transmission behind a chevy small block.
Do you check it while running and in park or neutral?
HeavyHauler is offline   Reply With Quote
Old 06-22-2019, 05:04 PM   #2
72LB
72LB's Avatar
Re: How to properly check fluid level for 400 turbo transmission
Warm in park, running.
1985 C10 shortbed, current project.
Member of the Upstate SC GM Truck Club.
72LB is offline   Reply With Quote
Old 06-22-2019, 05:51 PM   #3
siggyfreud
siggyfreud's Avatar
But not after an extended drive. Let it run for a few minutes, cycle through the gears, then check while still running.
siggyfreud is offline   Reply With Quote
Old 06-22-2019, 05:54 PM   #4
Getter-Done
Getter-Done's Avatar
Warm fluid, In Park, Engine running and on level ground.
84 Chevy K-20
Old 06-22-2019, 06:06 PM   #5
Grumpy old man
Grumpy old man's Avatar
Warm fluid, In Park, Engine running and on level ground ,Wearing your Chevy hat .
Old 06-22-2019, 06:15 PM   #6
Getter-Done
84 Chevy K-20
Old 06-22-2019, 07:25 PM   #7
too much stuff
Roadtrip!
too much stuff's Avatar
Warm fluid, in park, engine running and on level ground, wearing your chevy hat, on a cloudy day.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 06-22-2019, 09:33 PM   #8
Getter-Done
Only thing I can add to that is You must use a red shop rag to remove the fluid from the dipstick before you check the fluid level.
HeavyHauler I hope you got a Good sense of humor .
Looks like we have took the (Fluid ) dipstick and run with it.
84 Chevy K-20
Old 06-22-2019, 09:58 PM   #9
Andy4639
Old member
Andy4639's Avatar
Talking Re: How to properly check fluid level for 400 turbo transmission
Ya'll for got safety glasses, apron and face shield just in case!
Seeing the USA in a 71
http://upstategmtrucks.com/
