Old 06-23-2019, 02:28 PM   #1
HeavyHauler
What is a good and durable overdrive transmission to use behind a bigblock chevy?
I am wanting to build a bigblock Chevy engine that will be about 600HP and the same amout if not more torque. What overdrive transmission will be able to handle that type of power?
HeavyHauler is offline   Reply With Quote
Old 06-23-2019, 02:30 PM   #2
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: What is a good and durable overdrive transmission to use behind a bigblock chevy?
Gear vendors
Old 06-23-2019, 06:38 PM   #3
Mike C
Mike C's Avatar
None of them stock. 4L80E is where I would be spending my money most likely. The TH400 with the gear vendors is another option and they say the TH700 can be built to take that power, but I am not a fan of the gear split on the 700. I am going to put a built Extreme Automatics in my 69 short step with the 427. But I am more like 450hp not 600.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-23-2019, 07:03 PM   #4
morepwr
4L80 would the choice if you don't want a Gear Vendor behind a Turbo 400.
morepwr is offline   Reply With Quote
Old 06-23-2019, 07:05 PM   #5
greasemonkey
greasemonkey's Avatar
Automatic or manual? The Tremec TKO can be bought rated for 600 lb ft, but that's a manual.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 06-24-2019, 07:49 AM   #6
4L80E for overdrive automatic. A great strong reliable transmission.
Old 06-24-2019, 10:24 AM   #7
HeavyHauler
I would definitely want automatic and it sounds like 4L80E would be the trans to get. I dont know anything about gear vendors and I dont want to cut up my truck trying to make something fit.
Old 06-24-2019, 10:58 AM   #8
HO455
HO455's Avatar
There shouldn't be any cutting of the truck to install the gear vendors unit. Other than the driveshaft. They are pretty rugged pieces I know of several low 10/high 9 second cars that run them without issue. Some of the differences between the two come down to the 4L80 will require an aftermarket computer to operate which gives you laptop adjustment capability. The 4L80 will also have a lock up convertor, but with the engine your installing I would assume you will forgo that for a high stall convertor. A T400 with gear vendors will be cheaper to repair down the road. Gear Vendors has been around since the 70's or longer. Here is a link to more information.
Happy Shopping!
http://67-72chevytrucks.com/vboard/s...d.php?t=764137
RIP Bob Parks.
Old 06-24-2019, 10:42 PM   #9
mike16
what about a np4500?
mike16 is offline   Reply With Quote
