Old 06-23-2019, 10:27 PM   #1
Hammond68
1970 rear end width?
I've searched the forum high and low. Would anyone know the outer drum to drum measurement on a wide 70 rear end? It was a change over year from narrow to wide. I'm trying to use my 72 5 lug axles in a 3.73 70 rear end. Mines 3.07 rha w rear end,open.
The rear end is a tda 0309 k code. I found one for 50 bucks, non posi but I'll fix that later.
1972 c10 cheyenne.
383 stroker 10-1
280 magnum comp cams
700r4 tranny.
Hammond68 is offline   Reply With Quote
Old 06-24-2019, 08:13 AM   #2
Mike C
Mike C's Avatar
Re: 1970 rear end width?
It’s the same overall width as the 71-72. Not sure what you are getting at. If you have 71-72 axles and you have a housing the same width as the 71-72 housing they will fit right in regardless of gear ratio.
If I remember there is a 3/4” difference per side so the wider rear is 1 1/2” more so than the narrow. 55.5” versus 57”. That’s flange to flange (where backing plate mounts not wheel mounting surface.)
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-24-2019, 08:39 PM   #3
Hammond68
Thanks mike, I could have explained the question better. Sometimes my phone has a 3 second lag on each letter I type. Then changes words on me to boot. It's a pain to go back and keep changing words.
I found a wide rear end 1970 6 lug. So my 5 lug axles should work. Now I'll need a series 4 posi carrier.
1972 c10 cheyenne.
383 stroker 10-1
700r4 tranny.
