Old 06-26-2019, 05:32 PM   #1
focusedontheprize
focusedontheprize's Avatar
Clamping Plates - 8 x 6.5 Wheels
I am in the process of replacing the wheels and tires. I am going from the 17" rims to 16" steels. After doing a little research it appears I need will need the clamping plates.
Does anyone know where I can buy these? Are they available aftermarket or will I have to source a set from a used vehicle? Thanks.
focusedontheprize is offline   Reply With Quote
Old 06-28-2019, 11:33 AM   #2
SCOTI
SCOTI's Avatar
Re: Clamping Plates - 8 x 6.5 Wheels
I couldn't find them new. I wound up selling my alum Alcoas to a board member & as part of the deal got the plates he was using. Prob going to be the classifieds, craigslist, or a wrecking yard as your source.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-28-2019, 09:20 PM   #3
1967KaiserM715
1967KaiserM715's Avatar
you will need to source a set from a used vehicle. carefully inspect the lug taper bore, if the taper is messed up severely it may constantly loosen up on you. there is typically plenty of meat on the clamping plate to clean up the taper, stock was a 45 degree, or more commonly known as a 90 degree cone.
1967KaiserM715 is offline   Reply With Quote
Old 06-28-2019, 11:25 PM   #4
focusedontheprize
Thanks Scoti and 1967Kaiser. It seems these are the final components I am missing before I can go forward with replacing everything.
Does anyone know if they offer a 16” 8x6.5 steel rim without having to use the clamp? I have been looking at Accuride’s product catalog mostly and those still require them
Old 06-28-2019, 11:31 PM   #5
kipps
Can anybody tell me what a "clamping plate" is?
I honestly have no idea, and Google isn't my friend today.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 06-29-2019, 12:35 AM   #6
mongocanfly
mongocanfly's Avatar
This kipps...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-29-2019, 12:40 AM   #7
mongocanfly
And focused...you have to have them for steel wheels because the rims can be reversed....one rim facing in,one facing out,,,so they cant cut the lug seat in the rim due to this...that's why the plate
Not saying they dont ,but I've not seen steels without the lug ring
I'd say hit the junk yards or pullaparts...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-29-2019, 12:52 AM   #8
focusedontheprize
Thank you Mongocanfly. I have been wondering why this is the case and that makes perfect sense.
Old 06-29-2019, 06:36 AM   #9
1967KaiserM715
I just found these,
https://www.crofttrailer.com/cr33521...heel-8-on-6-5/
It looks like it might require having rims with that 9th oblong hole. Or possibly cut the locating tab off the ring. Doesn't state taper either, but almost all trucks use a 90 degree cone as that provides the best clamping force.
Old 06-29-2019, 09:41 AM   #10
GonicGM
GonicGM's Avatar
I have some OEM used from 73-87 GM, as shown in image above, should be able to do set of 4.
83 K30 SRW 350 TH400 NP205 4.10 9' Fisher
85 K30 SRW 350 TH400 NP205 4.10
87 V3500 Dually 454 TBI SM465 NP205 4.10 9' Fisher
83 K2500 350 TH700R4 8600GVW Dual Tank 4.10
1973 Cheyenne Super 30 DRW Std Cab Z83 4.10
1976 Silverado C30 Std Cab 4.10 DRW (4 sale)
GonicGM is offline   Reply With Quote
Old 06-29-2019, 12:13 PM   #11
wileecoyote427
wileecoyote427's Avatar
If you search around they make a flanged lug nut so you don’t need the plates I believe it was a 97 p30 that my 19.5s came off they used them but you’d need the matching studs or find the right lugs here is a link https://www.summitracing.com/parts/r...silverado-3500
wileecoyote427 is offline   Reply With Quote
Old 06-29-2019, 12:18 PM   #12
wileecoyote427
That’s a dodge 9/16x 18 idk what stock 73-87 is off the top of my head
Old 06-29-2019, 01:10 PM   #13
1967KaiserM715
73-87(up to 1991 old style) used a 9/16-18 stud. I dont remember the previous cutoff, as they used a 1/2 inch stud, but I think that was up to 1972 only.
a flanged nut will work, the best design uses a captured washer, so the washer can spin
Old 06-29-2019, 05:04 PM   #14
SCOTI
SCOTI's Avatar
I used the Dodge flanged lug nuts until I got the clamping plates. I needed the clamping plates to allow using 'conversion' (external thread) lug nuts as they're required for my 'optional' look for my steelies (OE 88-98 caps or the full wheel hubcaps).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-29-2019, 06:11 PM   #15
wileecoyote427
They make the flanged lug nuts with the external threads but they are metric m14x1.50 that’s why I mentioned I wasn’t sure I thought they were older then what they were and available in a 9/16-18 my plan was powder coat my 19.5s silver rickson trim rings and stock silver center caps
Old 06-29-2019, 11:27 PM   #16
focusedontheprize
GonicGM - just sent you a PM.
Thanks for the link to the lug nuts, if I am unable to come up with clamps I will go that route. This is great, thank you everyone.
