Old 02-27-2018, 03:08 AM   #101
chevy.c10
chevy.c10's Avatar
Re: Saddle up 66 c10
Originally Posted by YellowPatina65 View Post
Just browsed your build...You are doing AWESOME work and have a really cool truck...short wheelbase AND big back window...very cool truck!!!!
I appreciate it! I worked really hard to get it and now i'm working even harder to make it as nice as I can.
chevy.c10 is offline   Reply With Quote
Old 02-27-2018, 03:15 AM   #102
chevy.c10
chevy.c10's Avatar
Originally Posted by step65 View Post
Truck is looking great. I copied what I found here for the rear shock mounting worked out perfect for me. http://67-72chevytrucks.com/vboard/s...d.php?t=451200
I had 4 inch drop but changed to 3" shocks work well for both drops.
I did 4 inches of drop in the rear and 2 in the front. Somebody on the forum here told me i'd be okay with the factory shock location. Is there any truth to that? I looked at the link to the other thread you posted but i'm still unsure.
Old 02-27-2018, 03:27 AM   #103
chevy.c10
chevy.c10's Avatar
Since the driveshaft was hitting the cross member that was attached to the trailing arms I had to do something. At first I was gonna shorten the trailing arms and move the cross member back but I decided not to and my dad thought of a better solution. We cut the top out and used to two pieces of steel to reinforce the cross member.
Old 02-27-2018, 11:17 AM   #104
step65
I heard it will work as well just the angle is not correct and the dampening will be effected. I opted to make the brackets it was like 13 bucks for the steel. I also changed out the cross member because the drive shaft would have hit. I think CPP and McCaughy both make one. Page one of following link shows what I did. You are doing great work can’t wait to see your finished truck.
http://67-72chevytrucks.com/vboard/s...d.php?t=593129
step65 is offline   Reply With Quote
Old 01-13-2019, 11:41 PM   #105
chevy.c10
chevy.c10's Avatar
Haven't been posted as much as i'd like but here is some of the progress i've been making. I picked up some brand new seats from a 2017 equinox and got them mocked up and mounted today before I took them back out. I also got the engine and transmission set in the truck and I bought a new master cylinder from wilwood since the t56 runs a hydraulic clutch. The stock one could have been used but I would have spent hours making a bracket and everything so I did something a little easier. Lastly i've been working on getting the kick panels close to where im happy with them. I dont think I posted pictures but I sprayed the whole front end in a coat a single stage black to see if my body work was coming out nicely and it helped me find a few spots needing attention and ive fixed the areas that needed the attention which moves me to needing to sand down everything again with 600 and it will be ready to paint. After I do that ill move on to the bed to start the major body work.
Old 01-13-2019, 11:43 PM   #106
chevy.c10
chevy.c10's Avatar
I also am looking for a borg warner t56 dust cover. I read that GM discontinued them and cant seem to locate any.
Old 04-25-2019, 09:33 PM   #107
chevy.c10
chevy.c10's Avatar
Been making some progress on the truck lately. I got the rear fuel tank and a new fuel pump mounted. I even fired the engine for the first time a couple weekends ago. Did a little bit of painting on some of the front end parts and have starting reassembling some things like inner fenders, the core support and new radiator.
Old 04-30-2019, 05:45 PM   #108
made2drag
made2drag's Avatar
nice project and progress!
made2drag is offline   Reply With Quote
Old 05-25-2019, 01:41 AM   #109
chevy.c10
chevy.c10's Avatar
Did some painting this week to the inside of the cab, turned out pretty good and it was really rewarding to see all the time I spent making the kickpanels straight and what seemed like and eternity sanding the roof. Let me know what people think about the color, its lighter in the pictures.
Old 05-25-2019, 01:44 AM   #110
chevy.c10
chevy.c10's Avatar
Kickpanels
Old 05-25-2019, 11:20 AM   #111
The Rocknrod
Moderator
The Rocknrod's Avatar
Looks great. Thanks for the updates.
Old 05-25-2019, 02:18 PM   #112
Grizz1963
Grizz1963's Avatar
Looking great.
Sooooon I will need to be back on mine.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 05-25-2019, 06:01 PM   #113
68Gold/white
Job well done!!!
I like that color. Few go original any more, it's looking good!!!
What brand radiator did you get???
68Gold/white is offline   Reply With Quote
Old 05-26-2019, 12:06 AM   #114
chevy.c10
chevy.c10's Avatar
Originally Posted by 68Gold/white View Post
Job well done!!!
Surprisingly enough the interior isn't an original color, I was having trouble finding examples of factory colors so I had to find one I thought would look good and I tried it. I chose a color from urekem and can post the name if someone is interested. I got the radiator from big car show/swap meet and don't remember the brand.
Old 05-31-2019, 09:29 PM   #115
pdxhall
pdxhall's Avatar
Nice work. It looks great,
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 06-03-2019, 03:24 PM   #116
Android04
Android04's Avatar
Looks good
Android04 is offline   Reply With Quote
Old 06-24-2019, 12:26 AM   #117
chevy.c10
chevy.c10's Avatar
A lot of research and hard work payed off. Switched my speedometer over to an electric programmable unit so I can have a functional speedometer and odometer with the t56 trans. I started by taking measurements with a caliper and printing some pieces to get the needle in the position is would have been in from the factory, next I 3d printed a small coupler to adapt the old needle to the new shaft diameter. Then I put sticker on the gauges, painted the needles and cluster housing. It turned out good so far but still have to hook power and signal to test functionality of the speedometer. I also added a tach and am really pleased with how it turned out.
Old 06-24-2019, 12:30 AM   #118
chevy.c10
chevy.c10's Avatar
Since my new car has electric choke, I put the button that cycles the setting for the speedometer in place of the old choke location. Also got the light switch, ignition, wipers and cigarette lighter in.
Old 06-25-2019, 09:10 AM   #119
aggie91
I'm just glad to be here!
aggie91's Avatar
Nice work on the cluster. What electronic speedo did you use for the conversion?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 06-27-2019, 06:13 PM   #120
chevy.c10
chevy.c10's Avatar
I got a custom programmable unit from a company called NVU I measures the sweep and then told them the degree and that it was 0-100 and they designed one to work for me. I haven tried using it yet but the quality seems okay.
Old 06-30-2019, 06:40 PM   #121
88Stanger
88Stanger's Avatar
great build so far....
88Stanger is offline   Reply With Quote
Old 07-01-2019, 08:06 AM   #122
chevy.c10
chevy.c10's Avatar
Thank you!
Old 07-01-2019, 05:04 PM   #123
aggie91
aggie91's Avatar
Very cool, I will keep that in mind as I finish up my LS swap this year...
Karl
The LST Challenge:
Old 07-17-2019, 11:55 PM   #124
chevy.c10
chevy.c10's Avatar
Did some painting, insulating/sound dampening, got the seats installed and bolted down and put the door seals on. The pictures I have now don't do the color any justice, it looks awesome! Now onto the fun getting the doors on without scratching the paint.
Old 07-18-2019, 07:28 AM   #125
Android04
Android04's Avatar
Looking good.
