Old 07-02-2019, 05:06 AM   #1
72velle
72velle's Avatar
Lubricant for door hinges?
What do I use to lubricate my door hinges and mechanisms?
3 in1, grease?
Thanks!
72velle is offline   Reply With Quote
Old 07-02-2019, 08:45 AM   #2
geezer#99
geezer#99's Avatar
Re: Lubricant for door hinges?
I’ve always used atf.
https://en.m.wikipedia.org/wiki/DEXRON
Old 07-02-2019, 09:49 AM   #3
cadillac_al
The owners manuals back in the day said to use engine oil.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 07-02-2019, 10:16 AM   #4
MJN
MJN's Avatar
I had historically used WD-40 or Liquid Wrench but since switched to AMSOIL MP.
https://www.amsoil.com/shop/by-produ...tal-protector/
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 07-02-2019, 11:51 AM   #5
fordguy40
I'm using WD40 spray lithium grease. It goes on a bit runny, but it dries to a thin, slightly opaque film.
A few Fords and a couple of Chevys
fordguy40 is offline   Reply With Quote
Old 07-02-2019, 12:40 PM   #6
truckin 79
I recently found Tri-flow, it is a bicycle chain lube. This stuff is great penetrates well and works great on door hinges, hood hinges, window tracks and hood latches. This stuff is amazing and very low odor with just a couple applications loosens metal to metal contact up in seconds. I used this one some rusty Trans Am seat tracks that were not moving at all. Once I applied this they were gliding along with no binding. I also used this on my trucks drivers hinge since the little star thing was not moving freely and I suspect is what broke the door hinge. A little dab and little star thing was moving and no more squeak.
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 07-02-2019, 02:46 PM   #7
Dead Parrot
I use what ever is in my blue oil can, which is usually 30w non-detergent oil.
Dead Parrot is offline   Reply With Quote
Old 07-02-2019, 06:03 PM   #8
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
ive always used spray lithium grease
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 07-03-2019, 01:40 AM   #9
Ad Cam
Ad Cam's Avatar
Fluid Film. Works great and it's solvent free.
Ad Cam is offline   Reply With Quote
Old 07-03-2019, 09:47 AM   #10
skyphix
After this thread popped up, I decided to try to lubricate one of my doors that used to pop and be really difficult to close once it was fully open.
I used WD40 - I am not a huge fan of it normally, but so far on my truck, it has recovered my sticky hood hinges and kept them healthy for 6 months now, and the door that popped that I was sure I was going to rebuild the hinge on? Works perfectly. I am sure some of the heavier stuff works better, and I may apply a heavier wax containing lubricant (like bike chain lubricant for wet environments) but for now, WD40 saved the day.
Eric
1980 C10 SWB
2003 Chevy Suburban 2500 LT
skyphix is offline   Reply With Quote
Old 07-03-2019, 10:20 AM   #11
Ditto
Old 07-03-2019, 10:41 AM   #12
focusedontheprize
focusedontheprize's Avatar
+1 here. I lubricated my hinges this weekend with this. Sprayed them into the pins and bushings and moved the door back and forth to work them in. They are incredibly smooth now.
focusedontheprize is offline   Reply With Quote
Old 07-09-2019, 03:39 AM   #13
Pontiac1976
Pontiac1976's Avatar
I used WD-40 w/ 10% 5W30 oil mixed in spray bottle. spring Then
I use some kind a spray lithium grease. keep out the water.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 07-13-2019, 10:17 AM   #14
Axle
Axle's Avatar
ATF has been the best long term. A few applications at first and then forgetaboutit for a long time.
Alex.
Axle is offline   Reply With Quote
