Old 07-03-2019, 05:42 PM   #1
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
81-87 rear brake circuit have residual check valve stock?
Do 81-87 rear brake line/ circuit have residual check valve stock or is it just a strait shot from the combo valve to rear brake hose?
Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 07-03-2019, 05:48 PM   #2
SCOTI
SCOTI's Avatar
Re: 81-87 rear brake circuit have residual check valve stock?
Clint
All the one's I've worked on were a straight shot after the prop valve. My 89 dually as well.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-03-2019, 05:54 PM   #3
87chevy.com
Thanks, I looked and didnt see anything other than what looked to be unions... but wanted to ask just in case
Old 07-03-2019, 06:48 PM   #4
SCOTI
SCOTI's Avatar
Yep.... Unions are all I recall seeing as well.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-09-2019, 01:20 PM   #5
GRADYS Performance
GRADYS Performance's Avatar
Wouldn't the Residual Pressure valve be located in the outlet of the Master Cylinder for the rear drum brakes?
GRADYS Performance is offline   Reply With Quote
Old 07-09-2019, 02:21 PM   #6
rpmerf
rpmerf's Avatar
Isn't there a valve in the prop valve that can flip and not give pressure to the rear? Should light up the BRAKE light on the dash. I believe there is a tool to hold it in place while bleeding
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 07-09-2019, 08:34 PM   #7
87chevy.com
Cpp has a tool to keep the Brake light from tripping... pretty crappy quality, its threads are too small so it feels like it is cross treading.. will it work yeah, will it damage anything no, but I will probably mak a tool out of the old sensor that I probably wont ever use... I picked up cop disc / disc valve finally.. I'll install it in a few weekends.
Just replaced the rear drop brake line..
Sum b, had to replace the brake end fitting as it rounded off.
Clint
Old 03-03-2020, 01:30 PM   #8
Hart_Rod
Hart_Rod's Avatar
Slightly off topic, but has anyone ever heard of anti-locking rear brakes on an 87? Any information on them? Just noticed it's on my window sticker.
Hart_Rod is offline   Reply With Quote
Old 03-03-2020, 05:27 PM   #9
Rob, 88's had it standard, so it could have been an option in 87. I have never owned or driven an 87 so not sure. Newest square I have had was an 83.
Old 03-03-2020, 06:41 PM   #10
Hart_Rod
Hart_Rod's Avatar
Interesting. I don't see any ABS modules, just thought it was interesting on this year model. Thanks Bill!
Old 03-03-2020, 07:18 PM   #11
kipps
I have an 87 3/4 ton. It came from the factory with a load-control valve above the rear axle. Supposedly under very heavy braking conditions, the rear of the truck would lift up, and would be prone to locking the rear brakes. This valve would close off the rear brake line, and reduce the chance of the rear locking up in these conditions. This valve is commonly removed.
I don't know if the 1/2 tons had the same valve. If so, GM may have called it anti-lock brakes, as a marketing gimmick.
Keith Seymore would know what's meant by "anti-lock brakes", I'm sure.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
