#726 |
I'm just glad to be here!
Re: Project Goldilocks, '66 C10 SWB BBW Build
Looks good. I like how you added that upper mounting point to the frame.
Whose upper ball joint are you using? Can you share the part number?
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#727 | |
https://www.speedwaymotors.com/QA1-1...tud,84116.html
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#728 |
Really cool to see you working on this again.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#729 |
30 pages i just went over of this build, and i am beyound impressed! You are a craftsman, pure and simple.
I just got a "66 factory shorty fleetside and i am planning on bagging it, not for autocross, but just because i like the look and well want to. So i watched and read what you are doing and how. It has opened my eyes to a few things, so thank you for writing all this. Cannot wait for any new updates. |
#730 | |
I'm excited to be back on it!
#731 |
![]() Join Date: Mar 2011
Hey, it's great to see you back Goldilocks, I took a 3 year break on Sanity after I retired but I'm back on it again. You know I'm a big fan of your work. I'll be following along.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
#732 |
Old and crusty
![]() Join Date: Jan 2009
Looking good! I will be watching the progress and can't wait to see what you do on the short stepper.
65 Chevy long wide daily driver - SOLD! 64 Chevy Short Step LS |
#733 |
I picked up the three link kit while I was in TN for the Rod Run last weekend. Got to meet Rob and take a tour of the shop. Next step will be to assemble the sheetmetal so I can figure out the front wheel width and offset, and then from that I can figure out an axle width. I want to run a square setup with the same offset front and rear so I can rotate the tires. I'll try a 295/40-18 to start with but that may be too tall up front.
I'd rather have a little bit narrower tire for autocross, a ton of pro-touring builds are running 315 and 335 square and that's probably ok for managing tire temps when pushing hard lap after lap on a road course but no tire is going to have time to come up to temp on an autocross run. A narrower tire puts more pressure per square inch on the tread blocks, forcing the tire into the surface better. At least on the Festivas, we've seen better better cold tire lap times on narrower tires, so I want to try that idea for autocross. 295's will also weigh less than 315's or 335's, and unsprung/rotating weight is doubly important. I'm thinking about going with Wilwood's ProSpindles to cut down on unsprung weight up front. ![]() Quick check of where the axle will roughly be... it's definitely going to need a step notch. ![]()
#734 |
Forgot to mention it in the earlier catch-up post, but I've been working on a '69 C10 we found about a year ago. It's been a filler project for when we're slow on our other jobs, so its taken awhile to get this far with it. It was one owner until we got it. It's pretty close to being ready to sell, I just have to assemble the bed floor and coat the paint with Penetrol. It was suppose to be a quick flip but I ended up spending too much time on it...
#735 |
Looking good👍
check out SANFORD build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522019 |
#736 |
Rollin' Old Skool
Nice job on the '69. Will make someone a cool ride for sure.
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
#737 |
No real progress made, but I did loosely assemble most of the sheetmetal. Now I can measure for wheel size/offset and axle width.
![]() ![]() I got the '69 finished up and sold it after putting a couple thousand miles on it. After getting it running I took it back over to let the previous owner see it like we'd promised. He was excited to see it again, and had recently found a pic of him and his brother with the truck on the day their dad brought it home from the dealership. ![]() ![]() ![]() ![]()
#738 |
Very cool👍
#739 |
![]() Join Date: Mar 2007
Its funny how something with no wheels and tires layout out on the concrete can look so cool....
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#740 |
Agreed 100%. Especially true when it's CLEAN sheet-metal.
#741 |
Moderator
![]() ![]() Join Date: Aug 2011
That's impressive.
#742 |
![]() Join Date: Jan 2015
Gotta say "You Da Man" Ive been following you also on the spi forum on the 66 f100......Gosh you do good work! keep up the good work bud!
#743 |
yep, great point!! damn fine job....
John 3:16 - Saved me... God Bless |
#744 | |
![]() Join Date: Jan 2012
#745 |
Nice build. I think I missed it in here somewhere, why did you go away from the 4200 idea?
#746 | ||
#747 |
It would be cool to hear the latest on this.
#748 |
I sold it in Feb '21, it has a new home in Tennessee on a Roadster Shop chassis. Just had too many irons in the fire and my friend Jay (jhrusk on here) had a friend that was looking for a mild patina Saddle short/fleet, so a deal was made. Hopefully the new owner will update the thread as they make progress.
I've since bought another '66 short/fleet that didn't need much work to get back on the road, that build thread is here- http://67-72chevytrucks.com/vboard/s...d.php?t=830351
#749 |
Sweet project! luckily the 4200's have been getting some attention now so there are more builds out there with them swapped in. I would love to do a 55 150 2dr sedan with 4200,colorado 5spd and awd. Something near stock look outside but more modern comfortable interior,ac,cruise etc
| Bookmarks |
| Thread Tools | |
| Display Modes | |
