Old 07-10-2019, 08:15 AM   #1051
8man
Re: "Project Orangepeel" 52 A.D
Very nice and the colors look great.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 07-10-2019, 10:29 AM   #1052
99 to Life
99 to Life's Avatar
love the attention to detail. your truck has it everywhere. nice job.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 07-10-2019, 09:19 PM   #1053
reaper71
reaper71's Avatar
8Man Thank's
99 Thank You I appreciate that!
Mark
reaper71 is offline   Reply With Quote
Old 07-11-2019, 02:00 AM   #1054
joedoh
joedoh's Avatar
shes really a beaut mark!
Old 07-11-2019, 07:30 AM   #1055
reaper71
reaper71's Avatar
Thanks Russ!
Old 07-11-2019, 10:29 AM   #1056
Rickysnickers
Originally Posted by reaper71 View Post
Going with manual steering as well. (like to feel the road) Mark..
As always, very nice! You are going to arms that will rival Popeye!
Old 07-11-2019, 09:03 PM   #1057
reaper71
reaper71's Avatar
Old 07-12-2019, 06:44 AM   #1058
gigamanx
Digging the gold and the engine. I'd be too keen to start it up just to hear that rumble haha. Too early yet though. What's next on the bucket list and have you done any more to the interior?
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 07-12-2019, 06:46 AM   #1059
gigamanx
Update:
Hey Guys I had to switch gears a bit (need parts to finish up my radiator splash pan) so I will be moving on to my gas filler idea.
The plan is to install it into the stake pocket.
Pic 1. Here is after I made my cuts into the inside of the bed.
I mocked up the filler as well. So I cutout all of the rear panel (tube will run through here) I'll be using 1 3/4 o.d tube and will all be welded and have 1 rubber connection between the tube and tank.
Pic 2. Close up of filler (popup style)
Pic 3. Here I was figuring out the angle for the 1st tube.
Pic 4. the 1st tube welded up, this will then be welded to the next extension.
I forgot to mention, This will All be removable
Mark
This is genius!!! I have an S10 gas tank so I could totally use the front stake pocket in the same way. Where did you find the pop up cap?
Old 07-12-2019, 07:56 AM   #1060
reaper71
reaper71's Avatar
I picked up the cap from Summit.
https://www.summitracing.com/parts/bkc-48-9606?seid=srese1&gclid=CjwKCAjw36DpBRAYEiwAmVVDMLtvC5roPoCY7wmk1DSN7KVSTSh6e5kK899i8AEJCTbakXY8q__rO BoC4R8QAvD_BwE
As far as the interior goes I am in the middle of several things in the works.
power windows,A/C,door pulls,inside levers for the doors and still need to build my console.
Mark
Old 07-12-2019, 08:02 AM   #1061
reaper71
reaper71's Avatar
Biker's Choice Screw-In Type Pop-Up Vented Gas Caps 48-9606
Biker's Choice 48-9606 - Biker's Choice Screw-In Type Pop-Up Vented Gas Caps
View All Media
https://static.summitracing.com/glob....jpg?rep=False
$59.99
Old 07-12-2019, 08:06 AM   #1062
reaper71
reaper71's Avatar
https://www.lowbrowcustoms.com/cycle...RoCKA0QAvD_BwE
They have them here as well.
Mark
Old 07-12-2019, 02:25 PM   #1063
mongocanfly
mongocanfly's Avatar
Manual steering...manual brakes...but power windiws???....come on Mark...haha
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 07-12-2019, 07:36 PM   #1064
reaper71
reaper71's Avatar
Gotta have some modern comforts somewhere!
Mark
Old 07-14-2019, 09:31 PM   #1065
reaper71
reaper71's Avatar
pic 1. These are my coil pack mounts I made.
I used 1/4-20 threaded rod and steel tubing I cut to length as spacers.
Pic 2,3 a few more shots of the brackets.
Old 07-14-2019, 09:34 PM   #1066
reaper71
reaper71's Avatar
Here are a few closer shots of the brackets and them.mounted to the crossmember on the sides of the motor.
Old 07-19-2019, 05:39 PM   #1067
gigamanx
Well look what showed up on Amazon this week Ready to start fabbing this weekend and see how it works. Crazy coincidence, I wanted to put it right behind the cab in that stake pocket and you mentioned you cut a piece out of your bed rail cause it was damaged. I walked out to mine and low and behold, I have a dent/crack in the steel above my chosen stake pocket. Thanks for the idea!
Old 07-19-2019, 08:50 PM   #1068
reaper71
reaper71's Avatar
Awesome,good luck with the new project!
Mark
Old 07-20-2019, 10:12 PM   #1069
gigamanx
Playing with fitment. The stake pocket has a lot more room than I thought! Going to run some exhaust pipe to the bottom since that will be permanent. Then I can run rubber from the bottom of the pipe to the tank for replacing it in 20 yrs when the fuel hose dries out.
Old 07-21-2019, 09:02 AM   #1070
reaper71
reaper71's Avatar
looking good!
Old 07-21-2019, 10:32 AM   #1071
gigamanx
looking good!
Don't know if I noticed in your earlier post. How did you handle the vent tube since its a venting cap. Did you just tie it back into the filler hose??
Old 07-21-2019, 06:37 PM   #1072
reaper71
reaper71's Avatar
haven't done anything with it yet till I finish the fuel system.
Mark
Old 08-05-2019, 11:27 AM   #1073
gigamanx
Ran into some issues on my exhaust pipe idea. It looks like I'm going to have to try some 2" flexible fuel pipe to route around the corners then some kind of reducer to get to the S10 tank. Slight mod to mine is I noticed I can sit the motorcycle cab in the hole in the top and if I ever need to replace the tube, I can pull the whole contraption out through the sheet metal cut out. Will show some pics when I get that far. For now, gotta figure out how to get to the fuel tank from the stake pocket I've already cut out.
Old 08-06-2019, 07:55 AM   #1074
reaper71
reaper71's Avatar
Yes it takes alot of planning,I must say.
If you have welding TIG wire or metal hangers you can make templates for the shapes you need to make the corners etc.
Mark
Old 08-12-2019, 08:25 AM   #1075
reaper71
reaper71's Avatar
Update:
Pic 1. I cut a large access hole for installing the power windows units.
And used 1x1 tube to reinforce the door.
Pic 2. Window unit mocked up.
Pic 3. Painted with POR.
Pic 4. All painted and insulated
Pic 5. Before installing the door I put the door seals on as well.
Mark
