I have a 1971 Chevy 1/2 ton step side 4x4. The power train is a 350 with a four speed granny 1st. I have had this truck for about 4 years. It is a project for my sons and I to work on. The 3 of us were driving home the other night. We hit a bump in the road. It was like the transfer case shifted into neutral. I have no movement out of it under power at all. I can can start it and shift. The clutch is working well. But I can not get power out of it. Any ideas would be helpful.
Thanks PAT |
Re: 1971 4 Speed Help
You will get a better answer soon, shift handle bolt did not snap off? the flat bar across the high low is still connected? That's all I got, hope it's an easy fix.
Active Member
![]() Join Date: Nov 2018
Check your linkage and your transmission mount underneath. I've had linkage pop out of place going through a ditch, and I've had a broken transmission mount cause a slight sideways shift that wouldn't allow the transfer case to shift. Two real easy checks and possibly a real easy fix.
#4 | |
All about them K’s
![]() Join Date: Jun 2014
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
