Manual to hydraulic clutch
I have an 83 k10 shortbed with an sm465. As everyone knows pre 85 has manual clutch pedals and linkage. I recently bought a set of vacuum pedals out of an 85 Chevy truck. I did not grab the bellhousing though. Anyone know of/ have a part number for a slave cylinder mounting bracket to an 83 bellhousing since im planning on keeping the sm465? Thanks
![]() ![]() Join Date: May 2015
Re: Manual to hydraulic clutch
I used a wildwood slave and had to fab my own bracket for mine for driver side clutch...im assuming your using a clutch arm with drivers side clutch arm....the factory nv bellhousing clutch release were on pass side
You can get a slave that actuates the mechanical fork and bearing, just as you can get a master actuated by the original clutch pedal. It's not that tough.
Just looking for a mounting bracket for the slave cylinder
I've read a few threads of others having to machine down the bellhousing to fit a slave bracket
#6 | |
Yeah I have the slave for it. Im just looking for a mounting bracket to attach it to the bellhousing since it didn't have one in 83. |
Novak-Adapt makes one for Jeep conversions that use a Chevrolet bellhousing and fork. Not sure if it is for the same bellhousing and/or slave you have but it might be worth a look.
heres the bracket I made for mine to use the slave with the drivers side fork
