Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 07-14-2019, 07:30 AM   #1
72freak
Rottenwood Garage Member
72freak's Avatar
HO72 coating brakes with gear lube. Help!
I have replaced the seals several times, the breather is not clogged and I really don't notice a grove on the axle tube.
It seems to do it when its worked hard. I would rather try to save this before I go to the 14 bolt conversion trouble.
Any ideas?
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 07-14-2019, 07:30 PM   #2
Bimus
Re: HO72 coating brakes with gear lube. Help!
I would try speedy sleeve and check how tight the seal fits .
on heavy trucks they come with a wear ring that is changed when the seal is changed and the smaller axles don't and they should .
I wen through this with my 52 Chevy one ton
Bimus is offline   Reply With Quote
Old 07-20-2019, 09:55 PM   #3
72freak
72freak's Avatar
Ttt
Old 07-22-2019, 01:00 PM   #4
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
What kind of shape are the bearings in? If it leaks after hauling a load I'd say that would be the place to start checking.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 07-24-2019, 01:27 PM   #5
72freak
72freak's Avatar
All are new.
Old 07-24-2019, 01:30 PM   #6
72freak
72freak's Avatar
The general consensus so far from the axle world is that the HO72 is not heavy duty enough for my application and does not hold enough fluid, its getting hot and that is what is taking my seals out. That would make sense as I don't have any troubles empty and it only does it when I have a heavy load on the truck.
Old 07-31-2019, 04:01 PM   #7
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Make certain that your bearings are adjusted properly. If they have enough tolerance, under load they can move far enough apart to let the axle rise and lose sealing. It doesn't take much.
~Steven
Simi Valley, CA
