Old 07-17-2019, 12:20 PM   #1
SilverGT3RS
Question on short term running engine without coolant
I have a 67 C10 with an LS swap....It is the LQ9 iron block.
Long story behind everything, so short story is I have been working on the truck, and it currently doesn't have a radiator in it.
I need to move the truck out of my garage, and onto a trailer to transport it to its new home. Is it safe to run the engine that long without coolant? I'm guessing no more than 5 minutes of running time.
Thanks!
SilverGT3RS is offline   Reply With Quote
Old 07-17-2019, 12:30 PM   #2
tinydb84
tinydb84's Avatar
Re: Question on short term running engine without coolant
I wouldn't run it for more than a few seconds. Grab a few friends and push it on the trailer if it doesn't have a winch.
David
Instagram: myfabguy
Old 07-17-2019, 12:35 PM   #3
Steeveedee
Who Changed This?
Steeveedee's Avatar
Does it have the coolant hoses on it? You could plug them all after filling the block with water and run it for the time needed (don't run the water pump). Guys fill the water jacket of their drag engines with an epoxy compound for strength. They drive up to the starting line, stage, and race without cooking the engine. I blew a hose on one of my old cars, and drove it several miles by starting it, getting up to speed and then shutting it off and coasting. Or get some help and push it like tiny says.
~Steven
Simi Valley, CA
Old 07-17-2019, 12:43 PM   #4
tinydb84
tinydb84's Avatar
Steve's suggestion would work well. I would have never thought to drive/coast. Great idea!
David
Instagram: myfabguy
Old 07-17-2019, 01:39 PM   #5
kidatheart
kidatheart's Avatar
Don’t forget to do something with the tranny lines before you start it if it is an automatic.
kidatheart is offline   Reply With Quote
Old 07-17-2019, 04:22 PM   #6
Steeveedee
Who Changed This?
Steeveedee's Avatar
Yeah, I didn't think of that! That could make quite a mess.
~Steven
Simi Valley, CA
Old 07-17-2019, 05:13 PM   #7
68Gold/white
I have done what Steve mentioned several times. Maybe even put some duct tape on the lower rad hose outlet on water pump (may need a zip tie to keep it in place), plug the heater hose out lets, cram it full of water..........
68Gold/white is offline   Reply With Quote
Old 07-17-2019, 05:54 PM   #8
saxart
saxart's Avatar
Can you push the truck right up to the trailer ramps, then start it so all you have to do is fire it up, drop it in gear and pull it up on the trailer? That shouldn't be more than about 20 seconds if you set it all up right in the first place. That shouldn't hurt it, but at 20 seconds your about at the end of your rope, so either get it up on the trailer in that amount of time, or shut it down and let it cool.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
Old 07-17-2019, 06:42 PM   #9
AussieinNC
Moderator
AussieinNC's Avatar
Connect the two auto cooler lines with a piece of rubber tube.
Have the trailer ready, ramps in place, start her up and drive it on, then shut it down....
This WILL NOT HURT THE ENGINE !!!!!!
Just do it and move on....
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 07-17-2019, 07:28 PM   #10
57taskforce
All about them K’s
57taskforce's Avatar
I agree.
Tyler
Old 07-17-2019, 08:11 PM   #11
truckster
truckster's Avatar
That's how I would do it... in fact, I have several times.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 07-17-2019, 08:46 PM   #12
leddzepp
Moderator
leddzepp's Avatar
This ^^^
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 07-17-2019, 08:48 PM   #13
Blue Rat
Think I would find a way to get it on trailer with starting it.
Blue Rat is offline   Reply With Quote
Old 07-18-2019, 07:29 AM   #14
jaros44sr
jaros44sr's Avatar
Park the tow vehicle with trailer attached at a 90 degree angle to each other, then use a second vehicle to pull the C10 onto trailer. Just did it to get my Jimmy to shop, flawless
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 07-18-2019, 07:37 AM   #15
ls1nova71
ls1nova71's Avatar
It's an LS engine, driving it on to a trailer without coolant wont hurt it. Apparently nobody seems to remember when the LS1 first came out, the Camaro brochure said that in the case of complete coolant loss, the car could be driven up to 50 miles, or something to that effect. Not that I would try that, but a minute or two wont hurt anything. If you're still worried about it, just fill the block with water through the upper hose, the thermostat is in the bottom hose so not much if any water will leak out in a short period of time as long as the belt is off the water pump.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 07-18-2019, 08:03 AM   #16
SilverGT3RS
Thanks for all the replies everyone, this such a great site. Ended up winching it up on the trailer, and when we off loaded it I had to start the truck for about 25 seconds to get it off an incline so we could continue to roll it into the garage. I can state that everything seems ok, and there weren’t any noises or smoke or fires. Lol.
