Old 10-26-2018, 02:16 PM   #76
3.d.autorepair
Re: 67-72 Suburban OE seats
Thank you for the info.
3.d.autorepair is offline   Reply With Quote
Old 10-26-2018, 02:19 PM   #77
3.d.autorepair
Also I am wondering if anyone has a source for an led light kit for these trucks? I have seen where you can buy the lights individual just wondering if there is a kit out there?
Old 07-29-2019, 12:29 PM   #78
CG
BlahBlahBlah
Not sure if this will even be seen or not (older thread). Is a full width second row bench the same as a front bench seat? Obviously the mounting brackets are different. I'm just talking about the seat itself minus brackets.
Old 07-29-2019, 12:32 PM   #79
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Mark
the bottom frames are different making the brackets not interchangeable
Richard
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 07-29-2019, 01:52 PM   #80
CG
BlahBlahBlah
Ok that's interesting. Thanks ... I should have known just to ask you. You have the burbs and panels figured inside and out ... Thanks!
But my guess is that if I have an extra front burb bench seat cover it would also fit the wide second bench unless the frame differences are more than how the brackets attach at the bottom.
Old 07-29-2019, 02:58 PM   #81
richard2717
I would think the covers interchange. The bracket mounting is the only difference I have noticed.
Members I have met.
Old 08-06-2019, 11:23 PM   #82
72-k20-burb
Question - are these homemade seats, or from something else?
My rig came with all three seats in it. Front seat is a-ok.
Mid row uses the stock front bolt holes (nuts on underside) but rear ones just go through plywood. Third row seat goes through plywood as well.
It appears these brackets are different from what everyone else has got... I know the plates that are welded on look wrong, even though they work and use all the original holes..
What are these from? Upholstery pattern doesn't match my old front seat, and the arm rests are blocks of wood that have been upholstered...?
Thoughts?
I'd rather not have to find two used benches, people want a mint for them.
third row
middle seat
both
way it was mounted when I first got it.. on a carpeted block?
72-k20-burb is offline   Reply With Quote
Old 08-07-2019, 05:55 AM   #83
richard2717
The seats kinda look correct but with home made brackets on them. Would need to see straight on shot of the bottom of the seat to see if the correct mounting holes are in the frame. Might be just a simple bracket change to get them right. 2nd row brackets are not too costly but 3rd row can add up quick. I think I still have a couple sets of 2nd row on the parts board for sale if you end up needing some. here is a general reference pic for the bracket attachment.
Members I have met.
Old 08-07-2019, 08:03 AM   #84
vectorit
What?
vectorit's Avatar
The rear anchor bolts on wood should be using steel cross beams with welded nut. I think I posted a picture of one of them, you should be able to see it looking in the rear wheel well.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 08-09-2019, 04:51 PM   #85
72-k20-burb
I started destructively looking into it, this looks like threaded black pipe for support with plywood, and something slightly thinner bent and welded directly to the rigid pipe. Home made? Not a bad job all in all, other than the welds kind of suck.
Thinking I might need to find a new set of seats, or re-weld these for the time being.
So Richard let me know what you've got and I'll probably take them. Shipping across the US is probably crappy though.
Old 08-09-2019, 04:52 PM   #86
72-k20-burb
I found that picture, don't have it. I can make that easy enough, finding seats seems to be harder. Or just re-use these
Old 08-10-2019, 08:01 AM   #87
richard2717
Looking at those pics I think the entire seat is home made but I could be wrong.
Members I have met.
Old 08-13-2019, 12:55 PM   #88
ajgriffin
ajgriffin's Avatar
Hey folks, can someone tell me if the second seat brackets are different if the Suburban had dual tanks?
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
Old 08-13-2019, 01:33 PM   #89
Bigdav160
Bigdav160's Avatar
Do you have a SPID showing the auxiliary tank?
Knowing that it was a common accessory installed by the dealer I would suspect the seat bracket condition would depend on the manufacture of the tank.
Other people have shown pictures of their 'under the middle seat' gas tank. I don't remember anything particular with the installation but I might suggest searching this forum.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 08-13-2019, 04:38 PM   #90
richard2717
might be easier for you to post pics of the brackets you have
Members I have met.
Old 08-13-2019, 04:54 PM   #91
ajgriffin
ajgriffin's Avatar
That’s the problem...I don’t have any. I purchased a Burb and the seats weren’t installed. I asked the seller for the front brackets like the ones shown on page 1 of this thread and he doesn’t remember having those brackets. He is speculating it may be because there was a tank in the second row. All that being said, I’m trying to find out what should be there so I can get my seats mounted up
Old 08-13-2019, 05:00 PM   #92
richard2717
ah ok I read it wrong. If the tank is no longer there you should just need the standard 2nd row brackets like these. I think i still have a couple sets listed on the for sale board as well.
Members I have met.
Old 08-13-2019, 05:15 PM   #93
ajgriffin
ajgriffin's Avatar
Thanks for the info. I’m trying to work with the seller so I don’t HAVE to purchase new brackets. I may buy yours and send the seller the bill if he can’t get his hands on them.
Old 08-13-2019, 05:30 PM   #94
ajgriffin
ajgriffin's Avatar
Shoot me a link to your ad when you can.
Old 08-13-2019, 07:30 PM   #95
ajgriffin
ajgriffin's Avatar
So it turns out there is a different bracket if the truck had an auxiliary tank (see attached). If anyone has any leads for the other kind in the parts board let me know.
Old 08-13-2019, 07:35 PM   #96
richard2717
SO are you leaving the aux tank under the seat?
I brought one of my ads to the top in the classified if you need it
Members I have met.
Old 09-14-2019, 12:58 PM   #97
CG
BlahBlahBlah
Son: Dad what is this big metal box under my seat?
Dad: Turns around while driving. That's a gas tank kiddo.
Son: Dad please turn around and pay attention to the road.
Old 09-15-2019, 10:27 AM   #98
67see10
67see10's Avatar
So what’s the actual length of the short 2nd Row? I couldn’t read the numbers on the diagram posted.
67see10 is offline   Reply With Quote
Old 09-15-2019, 10:41 AM   #99
richard2717
Originally Posted by 67see10 View Post
so what’s the actual length of the short 2nd row? I couldn’t read the numbers on the diagram posted.
48"
Members I have met.
Old 09-19-2019, 07:17 PM   #100
adzints7
Junior Member
My apologies if this is covered, I scanned and could not find the answer directly: will a truck bench seat fit work for the front bench in a 1972 suburban? I understand the upholstery will not cover the back, but is the rest the same? Will I need to find suburban brackets and slides or did the truck and suburban use the same? I have swivel bucket seats out of a Monte Carlo and I am thinking of using those as a second or third row and have them turn inwards...but I need to find a bench for the front!
adzints7 is offline   Reply With Quote
