07-29-2019, 05:09 PM | #176 | |
Almost Satisfied
Re: 1971 Stepside LS Build
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
07-29-2019, 09:36 PM | #177 |
08-05-2019, 10:36 AM | #178 |
Almost Satisfied
Didn't make near the progress that I had hoped for this weekend. I did get all the surface rust cleaned off the bottom of the cab and it sealed it up. One more test fit coming up and then a little CRE Epoxy.
08-05-2019, 11:07 AM | #179 |
Progress is progress, looking good! Is that POR15?
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". |
08-05-2019, 11:35 AM | #180 |
I know the feeling. But like TA said, progress is progress. It's never quick enough!
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
08-05-2019, 02:59 PM | #181 | ||
Almost Satisfied
08-05-2019, 04:50 PM | #182 |
[QUOTE=1971Stepside;8571079]Well, I call it RichMan15 at $50 a quart
I use Chassis Saver, it's the same as POR15 but cheaper. I buy it from Amazon and they have a couple different sheens. I've used it on all of my frame components and it is nasty to work with, but incredibly tough.
08-06-2019, 12:50 PM | #183 |
Looking good! This humidity has been down right oppressive.
08-14-2019, 05:41 AM | #184 |
Nice build, I have not read all of it yet but I want to comment on the cold case rad, I am shocked to hear about what they did to you , I purchased mine a year ago and I complained about the steam port problem back then and they should have fixed it then but I see they did not and they went ahead and still shipped off the stock they had on hand, shame on them for thinking it would be OK.
I have a Holley pump set up and it had the steam port in the pump so I cut the steam port off the rad and welded the hole shut to make it work. You made a nice rad mount for the cold case , would you like to sell it to me ? Last edited by my kids toy; 08-14-2019 at 05:49 AM. |
08-14-2019, 09:25 AM | #185 | |
Almost Satisfied
Thanks for the compliments on the build.
08-14-2019, 07:16 PM | #186 |
Message sent
08-16-2019, 09:39 AM | #187 |
Project is looking great, I need to come check it out!
'71 C-10 SWB Shop Truck Currently 350/350, soon to be LS'd. |
08-17-2019, 06:08 AM | #188 |
I sent message but did not hear back from you incase you replied.
08-19-2019, 11:12 AM | #189 | ||
Almost Satisfied
08-26-2019, 09:59 AM | #190 |
Almost Satisfied
Got some time out in the garage this weekend. Had a little help sanding which was really cool. While the boys were inside playing video games the girls came out and worked on the truck.
Planning to put some primer on her this week and start re-test fitting all panels for final prep. I also worked on the tailgate a little by installing these so called hidden latches. They need more work. I'm not sure I really like them, but I haven't seen better options for the stepside gates. Hopefully once it is all painted I will like it better.
08-26-2019, 10:05 AM | #191 |
My hat's off to you for having the ability to get the ladies in your house to sand on your truck!
08-26-2019, 01:06 PM | #192 |
subbed for the amazing info, cant wait to see it finished.
1967 GMC C15 sb 6.0 lq4 pro daily. Named the “formula 10” |
08-26-2019, 04:55 PM | #193 |
Interesting. Do those slide metal on metal or is there a bushing of some kind that will keep them free sliding for many years down the road?
08-26-2019, 05:00 PM | #194 | |
Almost Satisfied
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." Last edited by 1971Stepside; 08-27-2019 at 03:07 PM. |
09-03-2019, 10:08 AM | #195 |
Almost Satisfied
Finally got her loaded and to the body shop so we can use a booth. Hope to get primer sprayed sometime in the next week depending on their schedule and when I can jump in.
Started the preliminary body work on the bed. It is mostly new, so not a whole lot to do. I cut the side marker out of the passenger fender because at one point I was going to remove them all. I have now decided to keep them, so I have to weld it back in. One step forward...two steps back.
09-03-2019, 10:10 AM | #196 |
That's exciting! I've only spent about 3 hours sanding on my cab so far and I already hate it.
09-03-2019, 10:14 AM | #197 |
Looks great! I did body work and paint "one" time. I apparently was not blessed with the patience to do body work. I get way to frustrated way to fast. Another step closer!
09-03-2019, 10:24 PM | #198 |
Lol, all this sounds like the hell I went through and didn't realize it till you guys say it in writing... I'm crackin up. That is exciting stepside, hope it goes quickly for you man.
09-05-2019, 09:28 AM | #199 |
Almost Satisfied
Long night, but we got three coats of epoxy down. Will have to flip the panels and do the other side tonight. Should be able to start test fitting panels this weekend. Overall, was pretty happy with my initial filler work. Found several spots on the back of the cab that will need more work when blocking. Was exciting to see it back in one color and looking fairly straight. Couldn't go to sleep last night after getting home...maybe it was the paint fumes
09-05-2019, 10:30 AM | #200 |
im dreading the day my project gets to the point of bodywork, but i take solace in knowing plenty of people have walked the tedious path of body and paint and that countless more will follow me.
