Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 07-31-2019, 12:56 PM   #1
chevyrestoguy
chevyrestoguy's Avatar
WTB: 12-Bolt carrier main caps
IF SOMEONE HAS A JUNK 12-BOLT CHEVY/GMC HOUSING:
I need a pair of the main caps (with bolts) out of a Chevy/GMC rear end housing. They will be for an experiment that I want to try on a 1st Gen Camaro 12-Bolt housing that all of my buddies are convinced is unsaveable.because it's missing a cap. Chevy used the same 3.062" OD bearing race on every 12-Bolt. I have machining tools (if needed) and the housing will be jigged during this experiment. I think I can make this work, my buddies don't. If it doesn't work, I'll buy an aftermarket cap set from Strange or Mark Williams.
If you've got a junk housing laying around let me know what you want for the pair.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 08-01-2019, 09:43 AM   #2
SmirchIs#1
Re: WTB: 12-Bolt carrier main caps
I have a 5 gallon bucket of 12 bolt caps from rears that I have scrapped over the years.I have fixed many rears that I have purchased with out caps.It is easy for me because I have so many caps to choose from.To bad I'm in upstate NY,because I would let you go through them till you found a good fit.What do you want to pay for a set of caps and bolts?
SmirchIs#1 is offline   Reply With Quote
Old 08-01-2019, 12:33 PM   #3
chevyrestoguy
I don't have any idea what they're worth, but here's what I'm working right now:
Our local self-service yards pretty much scrapped everything older than 1990, so finding ANY 12-bolt rear axle is nearly impossible. I just checked one of the yard's (LKQ) inventory, and they just got a 1973 Chevy delivery van in 2 days ago, and from the picture, it appears like it's got a 1/2 ton rear axle in it (5 lug rear). I plan to go over there tomorrow and see if it's the right one. The only issue is, their parts list does not have a specific price for this part. I'll have to yank it out and hope the guy at the counter is cool.
If it isn't the right rear end (like maybe someone swapped it for a 10-bolt), I'm definitely interested in what you've got.
Thanks for the reply! I'll keep you posted.......
My build threads:
Old 08-03-2019, 09:12 AM   #4
GonicGM
GonicGM's Avatar
I wish I was close! I actually made an indicator sweeping tool to measure parting line to bore depth to be able to pick caps. Cap bolt clearance hole offset to housing tap can offset bore parting line even with correct measured diameter of race bore.
83 K30 SRW 350 TH400 NP205 4.10 9' Fisher
85 K30 SRW 350 TH400 NP205 4.10
87 V3500 Dually 454 TBI SM465 NP205 4.10 9' Fisher
83 K2500 350 TH700R4 8600GVW Dual Tank 4.10
1973 Cheyenne Super 30 DRW Std Cab Z83 4.10
1976 Silverado C30 Std Cab 4.10 DRW (4 sale)
GonicGM is offline   Reply With Quote
Old 09-12-2019, 08:07 AM   #5
68 TT
Still plays with trucks
68 TT's Avatar
If you haven't found anything yet there is a place here in Spokane called Perfect Pattern Differentials that specializes in the car 12-bolt.
He may have few a sets in his collection but also may be able to measure what he has to give you a set that is machined the closest to what you need.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
