#3601 |
![]() Join Date: Mar 2011
Re: What did you do with your truck today, Part 3
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#3602 |
You probably got nothing done at work, just spent the whole day staring out at your cool truck!
In case it's not obvious, my truck is an econo-rod. I like my trucks to be trucks - unadorned and utilitarian, just as they were originally intended. Well that, and I'm a cheapskate too ;-) In that vein, I made some interior door pulls today out of an old leather belt. They work great and they match the rest of the interior. I'll probably replace the bolts with something more decorative eventually.
1951 Chevy Panel Truck Last edited by MiraclePieCo; 07-29-2019 at 11:09 PM. |
#3603 |
![]() Join Date: Oct 2016
Thanks Oldman3 and MiraclePieCo. I did go out 1/2 dozen times just to look at it!!!
MiraclePieCo, I envy how your Panel is coming out without spending the large dollars! I look at how much mine has cost and then remind myself that mine is the last thing on my bucket list and that I built it for me with every modern convenience that I could stuff in it, there are not very many people that have the funds to do what I did, and now I don't either!!!! |
#3604 | |
1951 Chevy Panel Truck |
#3606 |
I got another part bolted on the bed, got the body work done on one of the rear fenders and the other side much closer. Then came home and primed the tail gate hinges.
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
#3607 |
I drove it. After 2.5 years of working on it, it is street legal and I drove it on public streets with other cars. Sat for 28 years in my garage, worked on it for the next 2.5 years with a frame off, and now I can drive it. Still needs the interior done and new rims, but I drove it. Tomorrow off to the alignment shop, and I will drive it there as well. Dang, its my truck again!
1955 second series, 3200 standard bed, big window. Owned since 1975, decided it was time to do a frame off. 327, 4L80e, Ford 9 inch. |
#3608 | |
Whoo-Hoo! Looks awesome! great to see it on the road again! Happy driving
#3609 | |
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
#3610 |
Right on John! I read a story in a Rod Action magazine back in the seventies about driving the car you built for the first time and how all the busted knuckles and work is forgotten, isn't that the truth! What a day, how cool is that!
Brian
#3611 |
Big congrats on a job well done, looks great...Jim
#3612 |
Mdpaulson1, Thanks.
Dansportgarage, Thanks. I borrowed the color from Toyota, I think I wear it better. Those aren’t Cragars they are Cal Crome as a kid I had to buy knock offs. The rear are 15x10 the front are 15x6. I narrowed the rear to 56” because when I dropped the truck everything rubbed, also I put on some 4” tubs. Martinsr, yep this was my High School truck I had a 425 Olds/turbo 400 in it. After busting up a couple of rear ends, blowing the transmissions, and of course the engine I decided the SBC was a better choice since the truck was my daily driver and I need to get to work, daily. So now that it is back on the road it’s way cool. ![]() Oldman3, Thanks. There are a lot of REALLY nice trucks on this site, great information, lots of inspiration. John
#3613 | |
1951 Truck, LS1/4L60 1964 Suburban, current project 2014 Silverado daily driver 1953 Westerner "canned ham" trailer, rebuilt 1974 Prowler trailer, rebuilt |
#3614 |
Got five minutes in on my rear fender, that's it, done, I am beat.
Brian
#3615 | |
![]() Join Date: Sep 2016
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
#3616 | |
#3617 |
Got the tailgate on the bed, it's ready to put on the truck, if I can get that rear fender done tomorrow so I can get it in primer! Cross your fingers for me guys, I have GOT to get this bed on the truck next week at the latest!
Brian
#3618 |
Fingers crossed...Jim
#3619 |
Thanks Jim
Brian
#3620 |
got back on my vintage air. its completely installed and wired. I have two issue. issue 1) I didn't have enough of the ducting to hook up all of the vents. I left the far side vent (right by passenger door) unhooked. I figured I want all the air on my side. I will get another small section of the ducting and hook that up later. its really a non issue. issue 2) I was planning to run the compressor off its own belt. I have a two row pulley so why not? i measured and went to the parts store got my belt and installed it. it was a little short. it would work but i would prefer it be longer. the real issue though was that a bolt on the alternator bracket is in the way. its a small button head bolt. i decided to avoid this belt shredding bolt i would just run all of my stuff off the one belt. well a 59 inch belt isn't common. i can special order it. the other option is to remove the alternator bracket and counter sink the bolt. i have a drill press. im leaning more toward this for two reasons. if the 59 inch belt is hard to find what happens when it breaks and im not close to home? i leave the truck on the side of the road for two days while they order it unless its a weekend then its longer. the shorter belt can be had anywhere. reason two is that im afraid im going to have a lot of belt slip with a belt that long and no belt tensioner. so i guess its going to have to be counter sunk. really isn't that much work i just didn't want to do extra work. i can start the evacuation while i work on the bracket i guess. vintage air says you have to evacuate the system for 45 minutes and you are really supposed to let the system sit under vacuum for an hour before you charge it. so i can have all of that happening while i modify the bracket. sounds like a plan.
#3621 | |
![]() 1940 Ford Dlx Coupe 1969 Mach1 |
#3622 |
My56chevytruck,Thank you.
Those rims are a Cragar knock offs by Cal Chrome, back in 1976 I didn’t have the money for the real deal. I want to keep to the 15” wheel size. When I started the build I was thinking chrome reverse and moon caps, old school. Then I was thinking getting the existing re-chromed but I can buy Cragars for that cost so I put Cragars on my list of choices. Then I started looking a US mag with dark centers. It’s all still up in the air. I tubed the truck and narrowed the rear end so I can go wider. Those are 15x10, with 295/50/15 on them. Fits real well, but hey if you can wider, why not. May end up 15x11 and some of those M/T on it. Tires and wheel will be the last thing sense those are all new rubber. Getting my AC hoses in and the interior is top of the list. Maybe some pin stripping. If I go burn the tires off, that would move them up... good thing I put a line lock in it. ![]() ![]() John
#3623 | |
#3624 |
Got the fenders in polyester primer WHOOO HOOOOO!
Brian
#3625 |
They may not look different from the last photo but I got them blocked and primed in epoxy today, WHOO HOOOO! Ready to bolt the bed and fenders on to tow it to Idaho.
Brian
