Old 08-01-2019, 12:21 AM   #726
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
Re: What did you do to your truck today.The 3rd chapter
In the last few weeks I've transformed the bare bones farm truck into a CST
http://67-72chevytrucks.com/vboard/a...1&d=1564633085
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023
Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt.
Canuckvetter is offline   Reply With Quote
Old 08-01-2019, 06:40 AM   #727
72c20customcamper
72c20customcamper's Avatar
New rim's and tires. Before and after
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 08-02-2019, 09:30 PM   #728
WorkinLonghorn
WorkinLonghorn's Avatar
Replaced broken side mirror.CAUTION Work truck pictures ahead;
I was trying to tighten the mount and the stud broke at about 60 Ft.Lbs and almost broke my nose- did break my shades.
This is the original mirror from the 60s I'm sure. The curved piece is SOLID steel with the ends turned down and threaded. Here is a picture of the original compared to the cheapo aftermarket replacement that did NOT hold the mirror in place at speed because the threaded insert was not staked in the tube.
So I went to the local pick-your-part expecting to walk for miles but right there at the entrance was a nice 1978 with it's mirrors intact. Different style but at least it stays put in the wind. Added a spot mirror to the bottom. -BA
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 08-02-2019, 09:42 PM   #729
68bowtie
68bowtie's Avatar
Rad
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Thank you all so far you are angels!!
Old 08-03-2019, 12:08 AM   #730
rustytruck50
rustytruck50's Avatar
Received my new rear brake lines from Inline Tube for Raymond....PB Blaster, the proper tools & patience just doesn't overcome 47 years of rust
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 08-04-2019, 11:45 PM   #731
KQQL IT
At the body shop.
KQQL IT's Avatar
Busy weekend.
New 4 row aluminum radiator from Summit.
SUM-384018 had to notch the upper supports a little bit.
And finally got the bedliner sprayed in my other moneypit.
Old 08-05-2019, 07:58 AM   #732
67C10Step
67C10Step's Avatar
A couple minor accomplishments over the weekend.
After a few days of soaking all the lines and nuts I got the mater cylinder and distribution block removed. Soaking all the bleeders and line connections at the wheels so I can hopefully blow out the lines before I install the new master.
Sunday I thought I would quickly strip and prime one of the bed steps only do discover the finish goes in this order: clear, olive green metallic, mint green metallic, and primer. The greens and clear were laid on thick. After much sanding, blasting, and a bit of swearing I did get a quick coat of primer on the bare metal. Gotta come up with a better plan for the rest of the bed.
67C10Step is offline   Reply With Quote
Old 08-05-2019, 03:20 PM   #733
OregonNed
OregonNed's Avatar
Glove box project - finished getting the nice original stripped and primed - now ready for color...
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 08-05-2019, 04:25 PM   #734
Boog
laying low
Boog's Avatar
As is often the case when working on 40+ year old vehicles you can expect it to take twice as long and cost three times what you expected. Or vice versa. Welcome to our club.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 08-05-2019, 06:01 PM   #735
72c20customcamper
Didnt work on it but bought a nice OEM gate for the stepper. The bottom looks like its bent laying on the table but it straight. Not dents just a little surface rust.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-05-2019, 08:50 PM   #736
3757chevy
3757chevy's Avatar
That's nice.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 08-07-2019, 08:53 PM   #737
vitamin_c95
Well I was thumbing thru many threads of these trucks running rough and found that the HEI trucks are gapper at 45. My truck had auto lite platinum gapped at 35 from PO that still looked new and clean. Swapped out with a.c. Delco 43s gapped at 45. Wow. Runs so smooth now. Even starts better.
1971 C20 Longhorn 350/350 "Conquistador"
vitamin_c95 is offline   Reply With Quote
Old 08-08-2019, 02:55 AM   #738
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Neede a sheet of 4 x 8 plywood today so took the truck to Home Depot to get one.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 08-08-2019, 01:31 PM   #739
72c20customcamper
Got the tailgate down to bare metal time to weld up the tanneu cover holes that run along the top
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-08-2019, 02:50 PM   #740
72c20customcamper
All welded up .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-08-2019, 03:34 PM   #741
PepperTreeGarage
PepperTreeGarage's Avatar
Added Bumper Guards to the Shop Truck with the help of the "PTG Fur Baby Crew". LOL...……...........
PepperTreeGarage is offline   Reply With Quote
Old 08-08-2019, 04:49 PM   #742
Missourimark
Missourimark's Avatar
Replaced the bed wood and strips
Mark, 1969 custom camper, 454,th400,373posi
Missourimark is offline   Reply With Quote
Old 08-08-2019, 08:40 PM   #743
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Goodness what a difference!! It looks great! Nice job......
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 08-08-2019, 09:39 PM   #744
Missourimark
Thanks first bed I’ve done, truck is a custom camper , 133 wheelbase, all I can say is man thats a lot of screws and patience is a virtue.
Old 08-08-2019, 10:06 PM   #745
davischevy
davischevy's Avatar
You could have bought that plywood in Tennessee, and hauled it home in that Cheyenne you know.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 08-09-2019, 10:20 AM   #746
Mts67C10K20
Mts67C10K20's Avatar
Finaly had some time to work on my escalating project
Striped the core support a few weeks ago
Happy to see the trash bag sleeping bag prevented any surface rust
Here are the before, during and after
Mts67C10K20 is offline   Reply With Quote
Old 08-10-2019, 06:11 PM   #747
67C10Step
67C10Step's Avatar
More bed work. Starting to take the old wood bed out. Wouldn’t be so bad but some PO decided tongue and grove wood with a crap pot full of carriage bolts was the answer. And drill holes in all the cross sills for the bolts. Hope the sills aren’t trash when I get this out.
Also started straightening, stripping, and painting the rear fender braces. I’ll have two good sets for my project with at least one set left over. Still have a couple to take off the drivers side fender.
Old 08-10-2019, 06:19 PM   #748
Already Gone
I've actually been in contact with the seller of the truck and have the spid pic.
Old 08-10-2019, 06:22 PM   #749
KQQL IT
At the body shop.
KQQL IT's Avatar
Got my new to me cluster dialed in.
The lens was crappy and made the chrome bezel look less than new.
New lens new bezel my daughter repainted the needles.
Old 08-10-2019, 08:33 PM   #750
LuckyScott
LuckyScott's Avatar
1970 CST truck. The bed was really ugly and had a bunch of different colors of paint. Previous owner used the truck to haul house paint. Today my wife and I are applying Herculiner bed paint. Got the first coat on and it looks great, Gonna do the second coat in about an hour.
LuckyScott is offline   Reply With Quote
