drone- very slight vibration - not exhaust
Hi,
I have this weird drone that comes up around 30mph & 60mph (especially when cruising at those speeds). At first I thought it was exhaust/rpm/transmission thing but I've slipped the truck into neutral and the drone is still there as it coasts thru the 30/60mph range. When I put on the brakes there is no difference. There's no shimmy or anything like that. Just a slight vibration. In fact, if you didn't know the truck before you probably wouldn't notice. I think it has to do with the brakes/wheels somehow as I've recently had a brake job (new rotors/pads) put on. I have the disc conversion and wonder if they somehow used the wrong year parts (I don't know if they're early '70 or later '71-'72 parts). Or if that's even possible. any ideas? |
Re: drone- very slight vibration - not exhaust
Driveshaft out of balance or pinion angle incorrect.
Also possibly a bad u-joint. |
Who Changed This?
![]() Join Date: Jan 2013
Do you feel it in your hands (front of truck) or in the seat of your pants (drive line)? Does the inside rear view mirror vibrate (u-joints, diff)? Did it do it before the upgrade? The fact that it does it at 30 and 60 MPH tells me that it is a harmonic vibration (u-joints, diff). Not much help there, at the moment.
![]() Join Date: Feb 2016
I too had noise and vibration issues with my truck. Turned out that changing my carrier bearing and aligning my drive shaft took care of some of it. Then a look inside the differential revealed the other half of the problem. The carrier was failing as well as the spider gears.
I recommend checking with the carrier bearing and the drive shaft wear points to start. Then check the angles on the U-joints especially if the truck has been lowered or lifted. Hopefully you won't have to go through the whole rear end as I did. The WMB thread below has more information on what I did starting on page 13 post 312 and skipping around for several pages. Good Luck
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Definitely sounds like drive line but odd that you just noticed it after a brake job. Could be you were not noticing it until the brake job and (if you are like me) you get hyper sensitive for a while until you feel everything is ok.
Had s similar issue on my son’s Toyota Tacoma that has a carrier bearing as well. Toyota replaces the u joints Uber a recall but the slight vibration as still there. I got a digital angle gage and measured everything from the transmission back to the differential. Ended up shilling the carrier bearing down about 3/16” and it took care of 90% or more of the issue. |
The Older Generation
One easy thing to check would be the harmonic balancer on the front of the crankshaft. I have seen the rubber dampening strip pop out on the front or back and cause the balancer to wobble slightly. LockDoc
Thanks guys.... drive-shaft/differential most likely seeing how the rear-end is stock 67 (narrow rear end) and I did do some work on the driveline for the 5.3 conversion several years ago.
![]() Join Date: Jul 2016
Rear axle shaft bearings
