08-11-2019, 02:10 AM | #751 |
Re: What did you do to your truck today.The 3rd chapter
I couldn't be happier. Three guys showed up this morning, we mounted the cab, and then the primary paint dude and I spent the next 12 hours building the body today. I'm real impressed with this guy, he led most of the day.
We have a few minor adjustments left, but basically got her done. I finished the day torquing the body mounts to minimum. and that didn't change a thing, we're square and level too. Next up are the inner fenders, mount the bed, and mark for all the moldings. Then we blast her apart for paint There are going to be three guys working on the body and paint. My buddy, his brother and friend. They all work at the same shop. I suspect I may actually be done last next year or early the next 7-8 years I think Couple pics from today. And yeah Grumps you were right. All those body measurements I took before I tore the truck down was a wasted effort
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
08-11-2019, 09:58 AM | #752 |
A few custom touches with my dimple dies and bead roller.
C10ETC Instagram Last edited by 66clow; 08-11-2019 at 10:03 AM. |
08-11-2019, 10:28 AM | #753 |
Looking good. Nice custom touches.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
08-11-2019, 11:58 PM | #754 |
Got some 15x8 rallies from a fellow C10-er in Idaho. Painted them last week (Ochre) to match the accent stripes and interior. Installed = satisfied me.
08-12-2019, 08:40 AM | #755 |
A shout out to Daniel Stern Lighting for hooking me up with my new H4 headlamps.
1972 C30 Grain Hauler, 350/400 1967 1500 GMC Stepside SWB, In Transformation Process 1967 RS/SS Camaro 350/TKO600 |
08-13-2019, 08:29 AM | #756 |
landarts
Worked on building a cab cart that will also tilt forward for access to roof and floor bottom when needed. Cart will also have another extension off the back so it will hold a bed. The mounts are sleeved and will have clevis pins for raising and lowering if needed. In the future I will design a few other attachments that will sleeve in so I can mount a fenders, bedside, hood, etc for painting or body work.
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
08-14-2019, 11:06 PM | #757 | ||
08-15-2019, 07:26 PM | #758 |
Been searching forever to find an original tach cluster for my '69 C10.. FINALLY found one. Came out of a '71 C60 and even has the air pressure gauge! The guy was thinking on scrapping the heavy hauler since he hardly had any bites and I'm so glad I stuck to it and got him to pull it and ship it to me. Once it arrived, I started pulling it apart and got everything cleaned up and needles repainted/straightened. Cleaning that lens was nerve-wracking! Sweating the whole time lol ..but it turned out good. Put lights in it to match the theme of my truck. I used the bezel already in my truck since the one it wore had a big crack on the bottom and around the other mounting holes. The only thing left to do is put in the tach harness this weekend and she's ready to rock to the show on Sunday!
1969 C10 "Problem Child" 1981 C20 CCLB "Nightrain" "A good plan violently executed right now is far better than a perfect plan executed next week. Accept the challenges, so that you may feel the exhilaration of victory." |
08-15-2019, 07:40 PM | #759 |
Just out of curiosity, what is the air pressure gauge monitoring?
1969 GMC 2500. 250 I6, 4-speed w/ granny low |
08-15-2019, 07:43 PM | #760 |
On the C60, air brakes etc.. as of right now, nothing.. the future may hold something for it.. makes a nice conversation piece for now
08-15-2019, 08:55 PM | #761 |
70+ ( Old Skool Club )
You could stick a vacuum gauge in there with a line to the the intake tree. Thats the way mine is and the vacuum gauge works great.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
08-15-2019, 09:00 PM | #762 |
Started building filler panels
08-16-2019, 09:50 PM | #763 |
Slowly installing cab trim .
08-16-2019, 09:54 PM | #764 |
Today , I installed the center Ac vent and heater / Ac control . Wiring harness under dash and hook up to start soon. I am primarily test fitting everything . Will remove most of it to do wiring and then do my final install.
08-16-2019, 11:20 PM | #765 |
I've got red bulbs in mine, but they are barely visible unless it is pitch dark, and even then they are not very bright. Which bulbs did you use, and are they bright in person, or just in the pic due the the camera setting?
08-17-2019, 07:48 PM | #766 |
Topcoat on frame before & after. Swimming in deep water now!
08-17-2019, 07:58 PM | #767 |
Yeah, I figured the C10 didn't have any need for an air pressure gauge...unless you plan to put blower on it. Then it would be a great place for a boost gauge.
08-18-2019, 12:00 AM | #768 | |
That is a great idea. Boost gauge
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
08-18-2019, 01:29 PM | #769 |
Fueled up and finished my new to me ashtray for paint
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
08-18-2019, 02:07 PM | #770 |
Well, I was going to finish tearing all the old wood and welded in angle iron out of the bed of my truck but after changing oil/filter and spark plugs in my little work car it was already 95 outside and the humidity is making it feel like 102.
Did blast the underside of one step and get it primed Friday evening. Slow going during the dog days of summer. |
08-18-2019, 03:29 PM | #771 |
Paint my grill after straightening some of the dents to the best of my ability.
08-18-2019, 04:16 PM | #772 | |
I got my brakes done and drove the truck up to Mickey D's...the exhaust was a bit loud for the kids in the drive thru...had to shut the truck off to correct the order First time I've had the truck out on the street in about a year...felt real good!
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
08-18-2019, 05:40 PM | #773 |
Well, after stripping a thread in the bowl on the Rochester B carb, I had hoped that a machine shop could put Heli-coil inserts in, but no...drilled and tapped the holes out to allow a 1/4-28 bolt, punched 1/4 holes in the gasket, and drilled out the choke cable flange to 1/4 inch, put it all together and I’m back on the road...for the time being.... I’m happy!
"It is hard to search for a black cat in a dark room, particularly if it is not there. Especially if this cat is smart, brave, and polite." Sergei Shoigu, Russian Minister of Defense |
08-19-2019, 06:31 PM | #774 |
Got my A/C straightened out . Evacuated the system added some lube and recharged with new r12 . Just hair over 3 lbs 81° out and its blowing 41°.
Also started disassembly of the 68s nose to get ready to take the cab off. Very little rust so far none on the floors just the RH rocker And on a side note some nice CAB Tomahawk Texas steak for dinner .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
08-23-2019, 06:04 PM | #775 |
Well I did find some holes in the passenger floor. Not alot but decided to cut out the thin areas and replace . Used my stretcher and shrinker for the first time today makes life that much easier
