08-13-2019, 10:04 PM | #1 |
54 Brake Line Bracket
Hi,
Looking for a break line bracket for a 54, haven't seen on any online stores, any guidance be really appreciated. |
08-13-2019, 10:32 PM | #2 |
Re: 54 Brake Line Bracket
I have a notion that they are the same from 51 to 54. Hopefully someone has one out where they can take a clear photo of it or Maybe Joedoe or one of the other guys has one they can cut off an old rear headed to the scrap yard.
I'm thinking that a piece of 1/8 x 2 flatbar a couple inches long with the appropriate size hole drilled in it and the right bend in it spot welded to the axle is about all you need though If the hose has a flat on one side on he end to hold it in place use a drill that is the diameter of the measurement from the flat to the high point of the round part and then file or dremel the hole out so you have the flat alongwith the right size hole
