Old 08-14-2019, 02:52 PM   #1
bigmac73
bigmac73's Avatar
SPID question
Guys
As i strip my cab trying to get ready for paint, How do protect the SPID from getting either painted over or just scraped off
Or do I just remove it and get a new one made ( from board member) and up-to-date it with the extra options I have add to the truck so far?
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 08-14-2019, 05:31 PM   #2
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: SPID question
If you are going to paint the truck the same color remove the original glove box door and put it back on when done. If changing paint color still remove original glove box door then get one from a wreck and paint it to match and order a new spid from outintheshop.com, board member Chipflyer, and put the new spid on the repainted glove box door and keep your original safely tucked away intact. I'm doing exactly this only I bought a chrome glove box door and am spraying the middle wrinkle black and leaving the chrome outer lip as it will match the gauge surround.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 08-14-2019, 07:55 PM   #3
flashed
Re: SPID question
Save your original glove box door so you can prove what it was originally and paint another one to match . If you need one Im sure I can send you one .
flashed is offline   Reply With Quote
Old 08-14-2019, 08:03 PM   #4
68Blu
Re: SPID question
This is timely as I was planning to ask to same question. Thanks for the new glove box door idea!
68Blu is offline   Reply With Quote
Old 08-14-2019, 09:37 PM   #5
Re: SPID question
I always swap doors on trucks with SPIDs that I want to preserve when painting or chroming. I still have a few as momentos
