Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 02-23-2019, 02:07 PM   #1
JoeKan
JoeKan's Avatar
Heat and sound barriers
When you all carpet your trucks, do you install heat and/or sound barriers first? Does It Make A Big difference?
JoeKan is offline   Reply With Quote
Old 02-25-2019, 06:49 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Heat and sound barriers
I would put down some kinda insulating pad/layer....theres all kinds out there to choose from...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-25-2019, 10:23 PM   #3
AZ 67 C10
AZ 67 C10's Avatar
It makes enough of a difference that I would put some down. It doesn't need to be a major name brand either, the cheaper stuff works well, and it comes in different sizes and thickness too.
AZ 67 C10 is offline   Reply With Quote
Old 02-26-2019, 11:58 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Everything except the roof got some peel n stick. The rear cabwall got an extra layer of heavier deadener from the window down. Firewall also got a heat barrier layer.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-25-2019, 10:16 PM   #5
JoeKan
JoeKan's Avatar
Finally getting around to doing this. What's a good company to get heat barrier and insulation from? I'm going to order my carpet from Stock Interiors. Would that be a good place to get the hear/insulation too? Thanks!
Old 07-28-2019, 10:11 PM   #6
TKCR
TKCR's Avatar
I did this when I redid my interior. I put the Peel & Stick on the floor, back wall and on the ceiling, before putting the headliner back in. This is what I did:
On the floor, I had quite a bit of FatMat left over from a previous job. It wasn’t enough, so I got some Peel & Stick from Lowes. It is pretty much the same stuff as the FatMat, just cheaper.
Then put the original Tar Mat, from the factory back down. Then put a layer of jute backed foil down. I got this from Home Depot online. Use foil tape to adhere the edges to the floor, and on the seams.
https://www.homedepot.com/p/UltraTou...1406/100656748
Then the new carpet was put down. It also had jute backing. The back wall, I put the cardboard tool tray in and put Amp/speaker carpet on it. I believe it has made the cab a lot more quiet. When I first got the truck, the cab was so noisy, you had to talk pretty loud to be heard. Plus the floor doesn’t get hot around your feet, like it did at first.
Old 07-29-2019, 07:37 AM   #7
JoeKan
JoeKan's Avatar
Thanks TKCR, that's what I was looking for. You did a nice job on your your truck.
Old 07-29-2019, 11:00 AM   #8
TKCR
TKCR's Avatar
Thanks! And I forgot this part too, I also got this stuff from Home Depot. I stuffed it up in the corners, behind the speakers. I took it up as far as I could get my arm. I also made a few small updates to the post above.
https://www.homedepot.com/p/UltraTou...-202709974-_-N
Old 07-29-2019, 11:45 PM   #9
Wikid61
Wikid61's Avatar
https://www.fatmat.com/
Wikid61 is offline   Reply With Quote
Old 08-01-2019, 07:50 AM   #10
Chris(NJ)
I get all of mine from Second Skin Audio.
Chris(NJ) is offline   Reply With Quote
Old 08-21-2019, 11:28 PM   #11
mikelom
I used dynamat extreme on my car and I'm very pleased with its quality and performance.
mikelom is offline   Reply With Quote
