Old 06-07-2004, 05:24 PM   #1
Jeremy_5
Truck addict
Jeremy_5's Avatar
how to check a fuel pump?
What is the best way to see if my fuel pump is still working properly?
1956 Chevy Napco
1972 Cheyenne Super
1970 K20
Jeremy_5 is offline   Reply With Quote
Old 06-07-2004, 05:46 PM   #2
cdowns
cdowns's Avatar
unsrew the inlet to the carb put a hose on it into a jar turn the motor over for 5seconds and see if you've got gas in the jar
Old 06-07-2004, 06:07 PM   #3
thisolechevy
Correction unscrew the outlet to the carb. not the inlet
thisolechevy is offline   Reply With Quote
Old 06-07-2004, 06:08 PM   #4
Gene
Gene's Avatar
Buy a clear inline filter with replaceable inserts and see the fuel pumping.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 06-07-2004, 06:27 PM   #5
thisolechevy
Unhappy
wow wow my bad I read that wrong inlet to carb. outlet to pump. sorry
Old 06-07-2004, 08:52 PM   #6
ljbear
ljbear's Avatar
Probably the best way is to use a line pressure gauge on the discharge side of the pump while the engine is running. NAPA sells a decent gauge that is a pressure/Vacuum gauge that works well.
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
"Don't confuse enthusiasm with capability"
ljbear is offline   Reply With Quote
Old 06-07-2004, 09:44 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
A new fuel pump is about 15 bucks. How much trouble is it worth to you to just put a new one on?
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 06-07-2004, 10:07 PM   #8
Jeremy_5
Truck addict
Jeremy_5's Avatar
Tx Firefighter, thats a good point, but I would rather check it so if it is ok I can spend the $15 else where as the truck does need alot.
How much pressure is the fuel pump is suppose to put out?
1956 Chevy Napco
1972 Cheyenne Super
1970 K20
Old 06-07-2004, 10:53 PM   #9
1972C10
1972C10's Avatar
stock pump not much maybe 4 5 psi max?
1972C10 is offline   Reply With Quote
