Head Gaskets?
I have a Target Master 350 LM1
and I was going to put the Summit SUM-152123 heads on it. The Block is suggesting a 4.100" bore gasket and the heads are suggesting a 4.125" bore gasket. I'm not sure what gasket to get ![]() Thanks, Paul
Paul '68 C10 327/TH350 LWB ![]() |
#2 | |
Moderator
![]() Join Date: Jun 2017
Re: Head Gaskets?
The LM1 is better known as the target master 350 produced in mexico for gm from 1980 to 1994 it was GM,s economy 350 4 bolt main replacement motor rated at 185 HP 300 ft lbs torque and came complete less carb and dist. After 90 it came drilled for roller cams it is one of GM poorest produced replacement motors ever the cam only lasted 30.000 miles and where full of casting flanges not trimmed on the internals the would break of and cause engine failures . When new there was the need to be disassembled and cleaned up and cam replaced to make a reliable engine. ![]() ![]() ![]()
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox ![]() ![]() ![]() |
Tags |
double hump, engine and performance, head, head gasket, summit racing |
