06-07-2004, 10:19 PM | #1 |
Truck addict
leaking gasket on carb?
Recently I have noticed gasoline stains on my carb, I was wondering if this could be from a leaky gasket or improperly torqued bolts?
1956 Chevy Napco 1972 Cheyenne Super 1970 K20 |
06-08-2004, 12:09 AM | #2 |
What kind of carb?
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
06-09-2004, 01:08 AM | #3 |
Truck addict
4 barell quadrajet
06-09-2004, 01:16 AM | #4 |
Try tighting all the bowl screws. Just stains or is there gas on manifold?
06-09-2004, 03:07 PM | #5 |
Truck addict
it just looks like stains on the carb, no gas on the manifold, but it is leaking somewhere.
06-09-2004, 03:42 PM | #6 |
Normal condition --after a period of time gas will wick thru gaskets,pump rod hole, mist from pump squritor etc. Take a little carb cleaner and spray it every so often if you want it to stay clean.
06-09-2004, 05:05 PM | #7 |
Truck addict
thanks for your help, do I just spray the carb cleaner down the throat?
06-09-2004, 08:41 PM | #8 |
No-just spray the outside to keep it clean.(will not hurt the inside to spray it though)
06-10-2004, 01:49 AM | #9 |
Its Magically Delicious
i've always wondered about that ... if you spray'd carb cleaner down the primary barrel ... are you simply washing gunk down and around you float needle ... i've heard of guys removing the idle mixture screws and spraying it around through there .... i guess my question is .. Can you do more harm then good with carb cleaner ????
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
06-10-2004, 09:09 AM | #10 |
I'd say it depends on the time and method it is applied.
To spray a whole can down the throat of a cold, not running engine would be a bad idea! To spay a little down a hot running engine would be opposite. Ect.... Personally I just clean the outside of the carb. If you need to spray it out inside to make it run better it is probally something else. I would rebuild the carb.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
