Mechanic needed
Have a engine built an dyno tested put it
In now it has a noise in just seeing anyone near Jefferson ga could help.my hair is getting thin |
Moderator
![]() Join Date: Jun 2017
Re: Mechanic needed
Define the noise....
Metallic knock? Exhaust leak? Engine speed dependent? Louder when cold? Grinding metal to metal? ![]() ![]() ![]() ![]() ![]()
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox ![]() ![]() ![]() |
Re: Mechanic needed
I think its valve tran some where
Re: Mechanic needed
Ok
Re: Mechanic needed
Post a video.
Re: Mechanic needed
I guess I'll have to load it an take it a shop when there not busy
Re: Mechanic needed
Btt
Moderator
Re: Mechanic needed
What makes you think its in valve train?
Post a video of the engine running with sound...
Re: Mechanic needed
If it's not it's real bad would be a piston are rod bearing
![]() Join Date: Apr 2016
Re: Mechanic needed
You're not saying a lot in your posts. They are very short.
Re: Mechanic needed
Can get video to down load
Re: Mechanic needed
I can txt video
#13 | ||
"I ain't nobody, dork."
Re: Mechanic needed
Try uploading video via a computer. Are you using voice to text? your posts are really broken and jumbled up. Take it back to the shop that rebuilt it for you. That's where I would start.
Gary
![]() Join Date: Dec 2009
Re: Mechanic needed
Do you have a Stethoscope to locate (Narrow Down) the area of the Problem?
If you don't they can be purchased at your local auto parts stores. Here is a link below for reference. Link:https://www.ebay.com/itm/391357446557 .
