Old 09-03-2019, 06:35 PM   #1
pwdcougar
pwdcougar's Avatar
Help! Suburban body panel flatness!
Can someone please check the rear quarter panel flatness for me? I'm doing body work and can't determine if the rear quarter over the wheel well is perfectly flat or not. In the pictures I have a 6' aluminum ruler placed along the quarter. On the blue tape I've marked 1" increments from the edge of the wheel well. I'm holding the ruler at the 6" mark. When I do this the ends of the ruler are about 1/8" away from the body panels. This leads me to believe that there is a slight curve to the body panel. It is slightly bowed out right above the wheel well center line.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 09-03-2019, 11:16 PM   #2
pwdcougar
pwdcougar's Avatar
Re: Help! Suburban body panel flatness!
This can probably be checked with a piece of string and two people if you don’t want to lay a ruler along the side of your truck. Just hold it about 5” - 6” above the edge of the wheel well.
This body work is killing me!
Thanks in advance
Paul
Old 09-04-2019, 07:03 AM   #3
CG
BlahBlahBlah
I don't have a burb handy, but is it the same on both sides of the burb? To me that would tell me one way or another. What would be the chance of each side of the burb having the exact same damage? But being exactly (or super close) the same as you're measuring on both sides would indicate that is the way it is supposed to be.
Course I'm just a dork sitting 3000 miles away from your burb that is having trouble sleeping so when I read this later I may have a different point of view =)
Old 09-04-2019, 07:18 AM   #4
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Paul
While I can stand up this morning, i went over to the original paint one i have sitting here and at no point will my 6' straight edge sit flat. The closer you get to the wheel arch the bigger the end gaps so I would say it safe to say the panels are not flat.
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 09-04-2019, 08:09 AM   #5
pwdcougar
pwdcougar's Avatar
Originally Posted by richard2717 View Post
Paul
Thanks Richard! Take care of that back!
Paul
Old 09-04-2019, 10:41 PM   #6
HO455
HO455's Avatar
If you want a second opinion I can check mine in the morning and get back to you.
RIP Bob Parks.
Old 09-05-2019, 11:37 AM   #7
pwdcougar
pwdcougar's Avatar
If you could confirm Richard’s observations I’d really appreciate it!
Paul
Old 09-05-2019, 12:52 PM   #8
Killer Bee
Killer Bee's Avatar
here's a couple for what it's worth with a straight enough edge 4' piece of 1" al angle..
blue is 72 k1500 original body and paint..
primer is 71 k20 original body sanded in rusty primer
both fairly flat front edge of door jamb to about 3' back and starts to taper in towards the rear lamps..
my layman opinion it's fairly straight and flat along the sides fairing even with the doors and narrowing down slightly toward the rear..
ignore the troll in the back of the blue one
hope that helps and good luck!
Old 09-05-2019, 06:43 PM   #9
HO455
HO455's Avatar
Paul
My has the same amount curvature as everyone else's.
RIP Bob Parks.
Old 09-05-2019, 07:26 PM   #10
pwdcougar
pwdcougar's Avatar
Thanks guys for taking the time to check this. Body work is a pain in the butt.
Paul
Old 09-15-2019, 02:41 AM   #11
Average Joe
Average Joe's Avatar
This is going to be the straightest Suburban in modern history!
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
