#426 |
Re: Power Brake Booster Adapter Bracket
this will work with the CPP unit correct? What are price options with shipping?
#427 |
60-66 Nut
Once you remove the universal mounting bracket that comes with it, yes it should bolt up to my booster brackets.
As stated in post #1 of this for sale thread, the cost in bare steel is $55.00 plus $14.35 for shipping.
#428 |
Sent you an email I would like to purchase a 66 brake bracket.
Thanks |
#429 |
60-66 Nut
I've been emailing several people the past couple of days. Is your name John Robbins?
#430 |
60-66 Nut
After 10 years at the same price, I have had to raise my price due to an increase in my laser cutting costs.
#431 |
Hi John, I would like to purchase one of your powder coated power booster brake brackets for my 66 c10. can you please pm me with new total price thank you.
#432 |
60-66 Nut
PM sent.
#433 |
Hi John.... I am ready to buy a bracket from you. thanks, John
64 short fleet |
#434 |
Got mine for my 64 GMC, brilliant part and beautifully built. Looking forward to good stops. Nothing beats power steering and brakes.
1953 3100 261cu in, sm420, 3.55 torque tube, omaha orange 1964 GMC 1000 series,custom, 305E, sm420 |
#435 |
60-66 Nut
PL sent
#436 |
60-66 Nut
Thank you for the compliment
#437 |
![]() Join Date: Aug 2004
I need another bracket John, can you PM me your info please?
Posted via Mobile Device |
#438 |
60-66 Nut
PM sent.
#439 |
Got my bracket from Captainfab and was very happy with the quality of his manufactured part, fits and it was professionally cut and bent and drilled. I did not want to drill my firewall on my 64 GMC. At his advice picked up a full size power brake booster from the flaps and I updated to a dual reservoir master cylinger but at this time keeping it all drums so no need for a proportioning valve. I ended up cutting the eye off the booster rod and welding on a 3/8" by 24 thread female coupler on. Then will buy the speedway SSBC A1726 Universal Adjustable Master Cylinder Pushrod Kit to finsh off the pedal linkage. I did not want to cut or adapt the existing brake arm because they are getting scarce. All in all pretty straight forward, next week will see how it all works and will report back.
#440 |
Ended up buying this push rod from summit, ran less than $15 and some 3/8" by 24 threads per inch all thread and put it all together. Road trip works like a champ, love the power brakes over the standard, makes it a nice easy driver. Bolting the booster to the bracket went easier than I thought. It is made so you can use a 9/16" open and box end wrench without clearance issues. All in all I give the bracket a solid 10 out of ten and power brake addition a pretty cheap and easy modification for under $200. Cant beat that with a stick.
https://www.summitracing.com/parts/rsd-rc14
#441 |
60-66 Nut
Thanks for posting your pics and also the info on the pushrod.
#442 |
Hi,John,ready to purchase a powder coated power booster bracket for my 66 burb.i am going drum/drum like you ,what m/c did you use?
#443 |
60-66 Nut
I used a master for a '67-'70 C10. I will send you a PM.
#444 |
Hi John, just received your bracket ,very nice piece of kit,
#445 |
60-66 Nut
Thanks for the compliment. I'm glad you received it. I was a little worried with all the international restrictions being enacted. I am still here building and shipping orders. I work alone so the distancing mandate isn't too hard to follow
#446 | |
![]() Join Date: Jan 2013
Captain, Well it has been just about 13 months since I purchased your BBB (Brake Booster Bracket) for my 63 Suburban. I am finally getting around to doing the suspension and motor swap. I am converting over to 5x5 disks front and rear. I will be sourcing the booster and MC from CPP, not sure what size that I will be running - 8"? but what do I need to ask for as I am not sure if the bracket came with paperwork but if so it is long gone! Thanks!
Sent by the random thoughts from the voices in my head... |
#447 |
60-66 Nut
All of my booster brackets come with a list of compatible boosters including part numbers. If you are buying a booster from CPP it should work as most of the aftermarket universal boosters have the same 3-3/8" x 3-3/8" mounting stud pattern. There are a couple of the compatible factory boosters in post #1 of this for sale thread and in post #183 on page 8 is a list of several more.
#448 | |
Thanks for the update! Eric.
#449 |
If I purchase your bracket, do I need to drill a hole 1 inch lower on my brake pedal ?
#450 |
60-66 Nut
You do not have to, but most people like the feel of the pedal better with lowering the attachment hole 1" from original. The angle of the booster bracket keeps the pushrod fairly straight when you do.
