09-14-2019, 06:38 PM | #3751 |
Re: What did you do with your truck today, Part 3
I just got home from a car show of almost 150 cars and trucks, and I actually won a trophy! I guess the time on the dash helped, It was for Distinguished Dash. Exciting feeling to see a "dot" on my headlight!
09-14-2019, 08:36 PM | #3752 | |
https://static.speedwaymotors.com/pdf/916-31939.pdf That could also be the problem
1951 Truck, LS1/4L60 1964 Suburban, current project 2014 Silverado daily driver 1953 Westerner "canned ham" trailer, rebuilt 1974 Prowler trailer, rebuilt |
09-14-2019, 09:04 PM | #3753 |
push rod length has been checked & is correct.
I did move the rear brake line to the front chamber port. pedal stays firm with engine off or running. so today I ran across another idea while searching the internet. Some one else had a similar problem and it turned out that his m/c didn't have enough fluid volume in the chamber to move the wheel cylinders. they didn't match the m/c. so I checked mine. I have 1" wheel cylinders and the match to the m/c is 13/16" that's not much but its worth changing them out. wish me luck. Last edited by nvrdone; 09-14-2019 at 09:06 PM. Reason: spelling |
09-14-2019, 09:13 PM | #3754 |
Cruse in @ The Sonic in town. Major HOT only about 10 others showed
09-14-2019, 11:19 PM | #3755 | |
https://m.youtube.com/watch?v=qPLaPv8DITE
09-14-2019, 11:32 PM | #3756 |
idbeast, congrats...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
09-15-2019, 03:49 AM | #3757 |
Well-deserved!
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
09-15-2019, 07:31 AM | #3758 |
Thanks Jim and Bob!!!
09-15-2019, 02:54 PM | #3759 |
jweb: the m/c was included in the kit from CPP. its a 79 mustang booster & m/c - disc / drum. the instructions say that the chamber closest to the booster ( larger one) is for the front brakes and the smaller chamber is for the rear brakes. to use drum brakes on the front, add a 10# check valve. with drum brakes, there is no proportioning valve.
if changing the rear wheel cylinders doesn't work, the next step would be to chance to a corvette style disc /disc m/c with 10# check valves in each side. |
09-15-2019, 10:21 PM | #3760 | |
09-15-2019, 10:56 PM | #3761 |
correct
09-15-2019, 11:19 PM | #3762 |
dansportgarage: you are correct. since ive still got the stock drums front & rear, I do have the 10# check valve in the front. The master cylinder is a disc / drum so that makes me think there is a check valve in the rear brake port in the m/c
09-17-2019, 03:13 AM | #3763 |
What did I do with my truck today? I entered it in the TOTM contest! YAY!
1951 Chevy Panel Truck |
09-17-2019, 07:56 AM | #3764 | ||
Jim W |
09-17-2019, 09:08 PM | #3765 |
Now that the truck is up and running, playing with small projects. Installed an F bomb under the hood.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
09-18-2019, 07:27 PM | #3766 |
09-19-2019, 07:25 PM | #3767 |
So cool to see you guys getting stuff done, getting to shows, so cool. I am still on hold with even touching mine after the move, can't wait to get back to my 5 minutes a day plan!
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
09-19-2019, 08:54 PM | #3768 |
Well, hey! At least you're in Idaho!
09-19-2019, 11:39 PM | #3769 | |
Temporarily installed the rear bumper to see how lose it would fit, not bad, but the repop bumper mounts need to go to work with me tomorrow so I can fix the bend in the 3/8 flat bar that is not at a 90 degree angle and trim the bottom of the mount where it attaches to the bumper as it will majorly tweak my chrome as it doesn't fit the crease in the bumper. Jim W |
09-20-2019, 09:34 AM | #3770 |
The most profound thing I have ever heard referring to reproduction parts. A friend of mine said it when he opened the box with some parts he got for his '65 Corvette years ago.
"If they wanted to be honest, instead of putting in the catalog Exactly as original, they would put, Similar to original, can be used if nothing else is available" Yep Brian
09-20-2019, 10:27 AM | #3771 | |
09-20-2019, 10:30 AM | #3772 | |
Brian
09-20-2019, 03:42 PM | #3773 |
If you have a Pontiac, Ames is the best in the business
09-20-2019, 03:50 PM | #3774 |
Gotta move on to plan B. The drive shaft hits the emergency brake cross bar when I foot "accidentally" push the accelerator to hard! Putting the 4th leaf back in and adding a c-notch.
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. |
09-20-2019, 05:19 PM | #3775 |
Yes, they are...
