09-15-2019, 01:12 PM | #26 |
Re: A '54 named Busty
looking good! you could maybe keep that mechanical fan if you moved that motor back a little or a lot.
09-16-2019, 11:50 AM | #27 |
been chassin' exhaust manifold threads like a Boss last night
09-21-2019, 12:20 PM | #28 |
got the modified C10 4x4 transmission crossmember on for the final time
09-25-2019, 03:11 AM | #29 |
"Gregster"
Looking good, strong work, good flow, fun to follow!!!!!!!! Nutz
Been there, wrecked that |
09-25-2019, 08:51 AM | #30 |
09-25-2019, 09:00 AM | #31 |
so this is embarrasing but although I have built a small block Chevy or two in my lifetime I did not realize there is a special tool to put on the harmonic balancer, now I knew there is a tool aka a pulley to take one off but not to put one on
so this is how I stripped the harmonic balancer 7/16-20 fine thread bolt, the darn starter got stuck in the flex plate and as I was tightening down the harmonic balancer I thought the engine would eventually turn over and nothing bad would happen to that bolt Last edited by Gregski; 05-03-2020 at 07:48 AM. |
09-25-2019, 10:00 AM | #32 |
yup, seen that before. some guys will also hammer it on. whaddya think that does to the thrust bearing?
I have some threaded rod that I screw in and then use a stack of lubed flat washers for that fancy pants bearing with a nut on the rod to pull the balancer in. the end of the rod is beat up from the special tool (vice grips) I use to remove the rod after. works like a charm. it was a home made late at night tool. |
09-27-2019, 12:17 AM | #33 |
I never knew that either, I did a timing chain on a 98 and just used the bolt!
09-28-2019, 06:38 PM | #34 |
so this is how I spun the engine over to ensure it still rotates freelie
09-28-2019, 06:41 PM | #35 |
and than the dance began - no matter how many taps and dies I have you never have the one you need, and this being a rare fine thread, we had to go shopping
Top Tip: a magnetic tip screw driver really helps extract the metal shavings |
09-28-2019, 08:49 PM | #36 |
nice
My build a 49 5 window ls1 4l60e on a TCI chassis http://67-72chevytrucks.com/vboard/s...d.php?t=754926 My travel blog The Wong Winding Road-Adventures of The Chinese Cowboy https://thewongwindingroad.blogspot.com/ |
09-29-2019, 09:58 AM | #37 |
and here's how I kept it real for the rest of the day, removing rivetes to install a proper battery tray
some I even had to drill out a little center hole to releave 70 years of pressure, man they sure built things to last back then Fun Level = 0 Last edited by Gregski; 05-03-2020 at 07:49 AM. |
09-29-2019, 10:02 AM | #38 |
I know this thread is really boring right now, I promise it will pick up, here I was shortening that timing tab, it's the little things on a project that exhaust you
I know that thing was chromed so I sanded it off and tried to tach weld it but my welds didn't stick and I had to be gentle as not to burn through it, so I went the rivet way and Bob's your Uncle Top Tip: I drill a hole on the 0 mark as on some tabs it's hard to see / find the zero |
09-29-2019, 01:11 PM | #39 |
Nice tip.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
09-29-2019, 05:16 PM | #40 | |
yep. I need a drawer for all the taps I needed just once.
10-01-2019, 09:14 AM | #41 |
10-01-2019, 08:13 PM | #42 |
so my -6 AN Russell adapters for the power steering box showed up
going to run a steel braided high pressure line and a regular rubber return one but use -6AN hose ends on both lines since I had to cut the end off of the tube coming off of the power steering pump and use a compression fitting on it so that it would point the right way |
10-01-2019, 08:16 PM | #43 |
and here's what the pump looks like
10-04-2019, 12:56 AM | #44 |
so things were going great until it was time to install the radiator with the electric fan
the darn Vortec water pump sticks out 7" and interferes with the electric fan |
10-04-2019, 01:01 AM | #45 |
the short SBC water pump only sticks out 5 1/2" so I tried that, that also did not work with the electric fan
10-04-2019, 01:03 AM | #46 |
so back to square one, short water pump and mechanical fan, plenty of clearance now, I am even going to add a 1" spacer to move the fan forward a little bit closer to the radiator and fandangle some sort of shroud for it
10-04-2019, 06:21 AM | #47 |
Love that "TIPS"!! Entertaining build. Keep it coming....
My Build - http://67-72chevytrucks.com/vboard/s...d.php?t=515876 |
10-04-2019, 09:17 AM | #48 |
10-04-2019, 09:22 AM | #49 |
OK, so let me just say that having three trucks things get a little confusing sometimes and I forget what goes with what and how. An '01 LS swapped '74, a 71 cab on a '69 chassis, and than this 99 Vortec engine in a second gen '78 Camaro subframe on this '54, so cut me some slack ha ha
so now that it is all coming back to me, I realize that non of the three alternator mounting bracket sets that I have will work, because they are all for the long water pump (one of the three shown below) I think sometimes in the 70s GM decided to switch from mounting the alternator on the driver side to the passenger side, and the general rule of thumb is and I may be totally wrong, keep in mind I am only talking about the small block here, also they decided to mount the alternator bracket to the long water pump, I HATE THAT, I hate it when one component hangs off of and needs to depend on another one, WHY? short water pump = alternator on driver side long water pump = alternator on passenger side |
10-04-2019, 12:45 PM | #50 |
Is it a push or pull fan. Could you move yours to the other side? I have my fan on the front of my rad and it leaves plenty of room between the rad and water pump. Just a thought.
