Old 09-17-2019, 04:06 PM   #1
SWB
Active Member
SWB's Avatar
72 C20 Front Lowering Springs
Question..C20 front coils are NOT the same as C10 correct??
*K10 SWB. Orange/White
*69 Ford F100 21K Actual Miles, 2nd owner in family since new
*67 Chevy II RestoMod, Wilwood all around,
Heights Pro G front sub,, Shockwave Air Ride, 383cu in etc..
SWB is offline   Reply With Quote
Old 09-17-2019, 04:41 PM   #2
SCOTI
SCOTI's Avatar
Re: 72 C20 Front Lowering Springs
It depends on how the truck was optioned. A C10 w/a factory big-block prob has the same coils as a 3/4 ton. They will interchange.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-18-2019, 01:15 PM   #3
rpmerf
rpmerf's Avatar
From what I've seen, there are 3 types of springs. If you search around for putting half ton springs on a 3/4 ton truck, you will find some threads with spring rates and such.
Spring types:
1/2 ton regular
1/2 ton heavy duty
3/4 ton regular
3/4 ton heavy duty
1/2 ton heavy duty and 3/4 ton regular are the same spring rate and installed height.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 09-18-2019, 01:16 PM   #4
rpmerf
rpmerf's Avatar
Spring types:
1/2 ton regular
1/2 ton heavy duty
3/4 ton regular
3/4 ton heavy duty
1997 GMC Suburban
