09-18-2019, 10:18 AM | #1 |
X- Piping Exhaust After Mufflers?
I'd Like To X-Pipe My Exhaust But Do To Cleareance Issues I Can't Do It Before My Mufflers..
Can I Do It After The Mufflers And Is There a Benefit? Posted via Mobile Device |
09-18-2019, 12:05 PM | #2 |
Re: X- Piping Exhaust After Mufflers?
You can still do it, and it might balance/mellow the sound a bit, but you won't get the flow benefits of a crossover. The idea is to balance the flow between sides before the restrictive parts of the exhaust (mufflers, cats, etc.).
What type of clearance issues are you facing? |
09-18-2019, 12:46 PM | #3 |
Im Running The Exhaust Through The Frame and With a 6-8 Drop I Dont Wanna Run The Exhaust Much Lower.
Thinking The Black Widow Exhaust Might Be a Bit Too Loud Posted via Mobile Device |
09-18-2019, 01:41 PM | #4 |
Any photos of your exhaust setup? I too am running mine through the frame currently, but have room for a crossover. The mufflers are actually outside the frame rails, and the crossover pipe is inside the frame rails.
09-18-2019, 02:06 PM | #5 |
09-18-2019, 10:16 PM | #6 |
By through the frame do you mean through the trailing arm crossmember or through the actual frame to run outside the frame? I'll be honest, of all the dual exhaust I have run on all the trucks I've owned I have never run a crossover
09-18-2019, 10:22 PM | #7 |
Through The Crossmember
Wont Be able To Post Pics Tonight. Next Time im at The Shop Posted via Mobile Device |
09-19-2019, 10:03 AM | #8 |
This is a cut and paste from a article on X Piping your exhaust:
"An American V8 with a cross-plane crank doesn't fire alternate banks consistently. The firing order means that you sometimes get successive exhaust pulses into the same manifold. In a dual exhaust, this means inconsistent pressure pulses in the two sides. Look up "beat frequency". When you have two frequencies that are almost -- but not quite -- the same, the difference causes a low frequency pulsation (beat frequency) that gives the American muscle car its distinctive low frequency rumble. The same thing happens in twin engine aircraft when you don't "synchronize" your props -- the rpm difference between the two props makes for a low frequency throb you can feel as an intermittent vibration. Source https://www.physicsforums.com/thread...cs-etc.596357/ |
09-19-2019, 05:00 PM | #9 |
I managed to chop up and stuff a 3" x- pipe and some dynaflow mufflers under my cab. If I had the resources, the lengths worked out where I could have punched holes in the xmember and run the exit pipes through.
