Old 09-18-2019, 04:29 PM   #1
77trailering
1980s model dash in 1977 c10
Does the 80s model dash fit a 1977 c10 without customizing?
77trailering is offline   Reply With Quote
Old 09-19-2019, 03:09 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: 1980s model dash in 1977 c10
yes it will I believe the vent pieces are even the same but it should bolt right in... will also have the hole where the VIN is stamped on the tag in the left corner ( I believe you have a VIN on the door pillar)
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 09-19-2019, 03:53 PM   #3
Prong
You'll also need the 81+ instrument cluster bezel as well to match.
Prong is offline   Reply With Quote
Old 09-21-2019, 09:18 PM   #4
Pontiac1976
Pontiac1976's Avatar
Hello there this may help you.
http://bowtieguy.proboards.com/threa...ce-bezels-fits
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
